TIME SLIP CHASER ,SMACK TALKING ,THREAD HIJACKING,HP TUNER , HELLNO THATS ME
Thread Starter #461
What percentage would you guess this is I’m saying somewhere between 50-60 % ethanol
I made reference lines so I’m saying 60% 404430B2-574A-43C1-9C30-08308B53A037.jpeg
Thread Starter #462
I DID SOME MORE TESTING WITH THE ETHANOL TODAY ,I HAD 4 GALLONS OF ETHANOL THAT I BOUGHT TWO WEEKS AGO AND DECIDED TO PUT IT IN AND TEST IT THE OTHER NIGHT I TOPPED OFF AGAIN AND THE PERCENTAGE OF ETHANOL DROPPED TO 55 FROM 57 ,AT WOT THAT DROPPED A 1/2 DEGREE OF TIMING FROM 18.5 TO 18 ,WHEN I ADDED THE 4.5 GALLONS I HAD AT THE SHOP THE ETHANOL WENT BACK UP TO 57.5 % AND WOT WENT BACK TO 18.5 ,,,I DROVE OUT TO THE PUMP AGAIN AND FILLED MT GAS CANS UP WITH 20 GALLONS OF FUEL AND TOPPED THE HELLCAT OF WITH ANOTHER 4.4 GALLONS ALL FOR A LITTEL LESS THE 50 DOLLARS ,,,
THE ETHANOL CONTENT WENT UP TO 68% THEN SETTLED TO 62.5 % I DID A WOT PULL 3RD THRU 5TH ,,TIMING AT WOT NOW IS 20 DEGREES AND STILL NO KNOCK RETARD, IN MY TUNE 21 DEGREES IS THE MAX SO I WOULD ASSUME ANOTHE 3% OF ETHANOL WOULD GET ME THERE ,ALSO BEING ITS THE FIRST PART OF THE TUNE I ASSUME CURT WOULD HAVE TUNED IT ON THE SAFE SIDE ,,MUST SAY THE ETHANOL IS IMPRESSIVE AND NETS AWESOME POWER
55% = 18.0 TIMING
57.5 = 18.5 TIMING
62.5 = 20 TIMING
55% = 18.0 TIMING
57.5 = 18.5 TIMING
62.5 = 20 TIMING
I'm confused , I thought ethanol was NOT good in our gas (93) ? now your wanting more of it ? …..Buckee's has 92 ethanol free that I thought about using ?
Thread Starter #464
REMEMBER IM DOING FLEX FUEL
ok , so a flex tune requires the use of ethanol ?
Thread Starter #466
YES UNLESS YOU HAVE DIESEL AVAILABLE LOL J/K
alright , this tuning & data logging is a little over my head. :oops:
Thread Starter #468
IT MADE ME NERVOUS AS WELL BUT ITS ACTUALLY SIMPLE
Im sure it is once you see it enough & have some guidance on what is normal , good or not so good within the tune or logging.
Thread Starter #470
I like the ethanol tune , with the 93 tune I might see a degree of knock retard one log and not see it the next so I am always logging but with the ethanol I feel more comfortable just punching it and don’t feel I will have to log constantly unless I make a change
Im think about the 3.17 pulley , & not having to retune or do injectors ?
Thread Starter #472
You’ll need my Jms so the injectors don’t max out
from what I've seen , it won't max out injectors ?....maybe 90% at most ?
Thread Starter #474
Trust me you will want it
If I do it & you still have it then we can talk , what do you want for it ?
Thread Starter #476
450 shipped Because your such a good guy , I paid 600 plus shipping from curt and as you know I didn’t use it long at all it’s plug and play and easy as apple pie to install
Extra butter on that please , LOL , ok I'll let you know latter if I plan to do it. thanks.
Thread Starter #478
Butter added lol
I know you said plug & play & had to run 1 wire up front somewhere to what ?
Thread Starter #480
You run the harness up to the gas pedal I ran mine under the carpet right next to the driver seat you will not have any wires to cut or splice at all the ground wire has an eyelet you can hook up right next to the battery, I’m telling you Forrest Gump could do the install
Latest Forum Posts
