TIME SLIP CHASER ,SMACK TALKING ,THREAD HIJACKING,HP TUNER , HELLNO THATS ME
Good info. I'm curious on this fuel pump deal now. Mine's set to 100% about 40% sooner than stock, so in my logs I see Commanded Fuel DC% and it shows 100.
He sent me some pics of it . It is a nice unit and true plug and play . I think it might be a good safety for the few time the car goes to the track . For any major upgrades and/or lots of racing I like the IE dual pump kits . That too is super simple to install .
Thread Starter #242
I bet you see it drop to 75 at times as well and even though your duty cycle is low when its dropping even to 75 psi your duty cycle will go up in turn ,it should stay at 79+ at wot if you log it you will see that the desired pressure is 80 at wot
Interesting, what are the exact pid names so I can double check? Is It:
Fuel Pump Commanded DC
Fuel Pressure (SAE)
Someone asked if the Demon pump was the same as the Hellcat. The answer is no. The Demon and Redeye both have dual fuel pumps where the standard Hellcat is single fuel pump only.
Thread Starter #244
I now monitor
desired fuel pressure
fuel pump command dc
fuel pressure
Cool, I'll add desired fuel pressure and see what it all looks like next go.
It's fun to learn ain't it lol
Thread Starter #247
I deleted the file line clip thread because mine came off on me today thankfully didn’t hurt anything I went to the shop and fabricated a clip myself that actually works better but I’m going to try another option this week I’ll update when I find out
Just an update this is the correct part we need for our cars
Heads up 4 parts stores here in town did not carry it I had to special order to get it so be prepared if you ever have to replace it
Man , you are having the worst luck with this fuel pump, line & clip.
Thread Starter #249
I think I found the actual clip that will be the fix , I will have it in next week but the clip I fabricated today worked out very nicely the problem with the 5/8 dorman part# 800-041 is it’s to big I believe our actual line size from measuring the fuel pump where the pressure line goes on is a 1/2 so I ordered dorman part # 800-040
Thread Starter #250
On the bright side I’m very fast at changing the Pumps :ROFLMAO:
I now monitor
fuel pressure
Tested yesterday and I see desired fuel pressure 80psi and fuel pressure matches at 80.x psi in the logs. At wot fuel pump commanded DC is set to 100% in my tune and that's what I see in the log as well.
Yeah , if I ever need to pull my pump , I'll get some advice from you for sure, the expert ! :LOL:
Thread Starter #255
Crazy stuff
Strap broke and damaged the brake.
Thread Starter #257
See I’m not the only unlucky one lol
Thread Starter #258
new clip installed proper size I hope my fuel pump days are done,,i tested to 100 psi of pressure and it held fine :)
Lets hope so , I know your ready to move to the next project o_O
Thread Starter #260
I th
ht
I thought about going to the overdrive but now I decided its enough the way it is im fairly positive in low da it will get a 10,0 maybe high 9s on my race tune
no sense in going any more isnt like i can go that fast on the streets and no street tires will grip decently enough for it with the 3.09 gears i have im already breaking the 10.5 indy 500 tires loose at 65 mph since i installed the boost a pump
Latest Forum Posts
