TIME SLIP CHASER ,SMACK TALKING ,THREAD HIJACKING,HP TUNER , HELLNO THATS ME
Thread Starter #221
Just installed the JMS BAP EASY Install plug and play for our hellcat I did some research and there was no negative info on these that I could find A245EC99-B179-41DC-BA78-EC47E4CD2919.jpeg 726E7BC7-C26C-4C0D-8617-200991E2063D.jpeg
So like no cutting wires plug and play? That might be an interesting option. Is it boost referenced or how is it activated?
Thread Starter #223
No wire cutting at all and it plugs into the fpcm and at the pedal it uses the throttle reference as to when to activate I’m setting mine to come on at 50%throttle and it ramps up from there to 100% when it’s wot I’m about to go make a couple of hits and log it to see how it does
Thread Starter #224
ok I did some logs a few hits up to 6500 wot the fuel pressure will hold 90-92 psi
it of course brought the injector duty cycle down to where it didn't go over 77 and the fuel pump duty cycle never went over 72%,i believe its no difference from added pressure through the tune except your fuel pump duty cycle is going to rise up if not max out at times out when that is done ,regular driving the JMS doesn't turn on ,if it continues like it is im one happy camper
Could a BAP be used instead of bigger fuel injectors when just going to a 2.85 or lower pulley ?
What is the differences between the JMS & the KB one ? …. cause you were looking at the KB.
Thread Starter #227
I’m not sure but your tuner would know the answer to that besides the demon injectors are about the same cost
I would be curious how much fuel pressure the demon runs and if it uses the same pump
Thread Starter #228
Is curt @ injected the same curt @dusteroff ???
I believe so.
Thread Starter #230
So are you gonna check your fuel pump from time to time to make sure you don't have any more rubber or coffee :LOL: in the tank any more ?
Thread Starter #232
curt suggested the jms and I happy he did it doesn't have to have a boost reference like the kb and with the kb I would have had to buy the extra adapter to put a pressure switch at the supercharger meaning that ugly wire harness addition under the hood look ,the jms was a no brainer,, cost was about 100 more but for not having to run wires thru the dash ,I was sold also the fact that no negative found on the site
Thread Starter #233
So are you gonna check your fuel pump from time to time to make you don't have any more rubber or coffee :LOL: in the tank any more ?
im cleaning the tank today lol
Thread Starter #234
this is an old post I found about the stock pumps as well
Also, keep in mind that stock there is a hard 89% duty cycle limit on the pumps in both the hellcats and demons so if your tuner doesn't know how to open that up you will be limited to 89% on the pumps.
Thread Starter #235
im so snake bit with the trash in that tank that even after I clean it I will check it lol
Thread Starter #236
stop giving me shit meancat I cant help it if my car like expresso
Man we need to teach you to edit a single post LOL
17.5 deg of ign advance on 93 octane? WOW
How is the throttle position wire connected? Is there a reference in the trunk or ? I've not been a BAP fan, but this plug and play deal is pretty cool.
I'm not familiar with the 89% limit on the stock pump. In the tune you can easily see 100% is commanded.
I sure hope that is a race gas tune and race gas in the tank !
Thread Starter #239
it jms comes with a harness that plugs directly into the pedal position sensor at the gas pedal I just ran it from the trunk under the carpets to the gas pedal it comes prewired everything connected perfectly the trunk looks normal no sign of the bap is showing ..also that 17.5 is race gas I still have race gas in it from the track .it runs 14.5 degrees on pump gas 93
also that quote came from injected engineering ,when you are seeing 100% on fuel pump its actually maxed out it shouldn't see 100
Good info. I'm curious on this fuel pump deal now. Mine's set to 100% about 40% sooner than stock, so in my logs I see Commanded Fuel DC% and it shows 100.
Latest Forum Posts
