2019 "Poverty Pak" Widebody Challenger
motorhead
motorhead
Ottawa
2019 Challenger HC Widebody
Thread Starter #241
Lucky you my driveway is gravel so inches of ice that has given way in spots from my Ram. Now that it froze again I don't think I have the ground clearance or traction to move the Cat or the Buick blocking it.😕
The plate is a nice touch.👍
The Cat looks good in those pics.😎
I spent an hour shovelling to facilitate the jostling of cars - had I left it I'd have been skidding all over the place as there was about 2" on the ground.
The Vanishing Point plate will go on the back for racing. I'll put the proper plate on the bracket and leave it in the trunk , and claim ignorance if I get pulled over.
Thanks, I thought it would be an interesting look against the snow... but, that's as far as I can go due to the salt monster lurking at the bottom of my driveway.
We still have awhile. Especially if like me you wait until the snow melts so that all that water running down the street isn't the result of the salty stuff they pushed to the sides all winter.
This is probably the hardest part of dealing with winter. It's getting nice enough to drive but if you do you might as well drive it all winter.
Did some actual work yesterday. First step was to uncover everything and play musical cars.
The wagon was blocking the Kitty in:
Then out came the big white whale:
Took some beauty shots:
Snow banks for scale.
View attachment 13737 View attachment 13738
Tossed it up on some ramps and got to work.
Car looks great!....for wide body. LOL. Seriously I don't know if you picked the right angles or what, but that thing looks AWESOME.
motorhead
motorhead
Ottawa
Thread Starter #244
It is an acquired taste... like looking at Cindy Crawford and past her mole.
Lol! I know lip moles are supposed to be sexy but for me, it’s a big nope.
Or this classic.
motorhead
motorhead
Ottawa
Thread Starter #247
Here's a little something I've been toying with since I got the car.
The design technique is called negative space - the idea is to highlight what is normally deleted by the eye to shape the image in your mind without being obtuse or blatant about it. I've got a few different designs sketched out, and decided to try and transfer one into reality.
For those not aware I have a background in design - so this is really my first love. The ultimate goal is to not be garish, it has to fit and look organic. That being said, I am not totally sold on this version... but it's a start.
Zero reduction in function (those LEDs are bright!):
Not bad for hand-cut vinyl, eh?
Pretty cool. Maybe even marketable.
motorhead
motorhead
Ottawa
Thread Starter #249
Thanks, but I don't have the interest in pursuing that kind of initiative.
Looks good. 😎
But finding Granite Crystal vinyl could be difficult.
NOT a mole guy at all....don't want em in my back yard...or on my women....
motorhead
motorhead
Ottawa
Thread Starter #252
motorhead
motorhead
Ottawa
Thread Starter #253
So today I learned a little something that may uniquely apply to the 2018+ HC platforms regarding HP Tuners and which Suite to run. I don't think it is written anywhere (at least that I found since buying the my car) but in order to properly read and scan the car you must be running the Beta version (4.5 or better) of the Suite, not the 4.4.x production version. Otherwise you get minimal access to scan data and cannot open anything read off the ECM. Took a few minutes to resolve... but I can confirm that both a Read Entire and the scanning functions work properly now.
I also dropped my drag pack stuff off for mounting and balancing. The shop was more than willing to use balancing beads (had them in stock) and fully agreed with the premise and rationale. So there... :p
Slows2k
2018 Challenger
Looking forward to the pics with the drag wheels on
motorhead
motorhead
Ottawa
Thread Starter #255
Me too. I've been completely enamored with the "Demon" drag-look since that car's debut.
In other news I tried another font style/design for the other marker light. Hand drawing and hand cutting this out is very laborious - I think I need a small vinyl cutter plotter thingy. The border I added made installing it a royal PITA, so that won't be making the grade. And no, I didn't accidentally put it on backwards - I deliberately mirrored it.
This is all me spit-balling ideas to see what sticks... get it?
motorhead
motorhead
Ottawa
Thread Starter #256
Picked my drag pack up from the shop today. They put 4 ounces of beads in all four wheels as the fronts weigh just about as much as the rears. The rears went on without lube and they elected to bead seal them to reduce slippage - not quite what I asked for but I guess they'll hold air just fine. The rears also have screw-in valve stems for good measure. And that 4 inches of lip out back is giving me the weirdest boner...
IMG_20200310_175817.jpg IMG_20200310_175846.jpg IMG_20200310_175917.jpg IMG_20200310_175922.jpg IMG_20200310_175950.jpg IMG_20200310_180420.jpg IMG_20200310_180519.jpg
Markp
Fuck Trudeau
Looking good. What made you go with the M&Hs?
Looks good for sure. So 4 oz eh! Good to know.
motorhead
motorhead
Ottawa
Thread Starter #259
Thanks.
Because I had them on hand (like new from DW 2016). Originally (IIRC) M&H was the first to market a 28" tall tire for a 17" rim, and I had good results with them over the years so I didn't hesitate to run them on this car. They have a pretty soft sidewall.
motorhead
motorhead
Ottawa
Thread Starter #260
I think you're going to be okay with 2.5oz with the lighter bias ply tires. I believe they wanted to put 3oz in mine but err'd on the side of caution.
