Anyone Ever Use the Factory Supplied AIR DEFLECTORS???
TrackDay
Great White North
2016 Dodge Challenger
The factory engineers stated the combination of the underbody ducts and the air deflectors allowed more laps to be driven at full boogie before experiencing fade.
I bought both for my 16 Challenger and use Hawk DTC70 pads with titanium brake pad to caliper shims and Castrol SRF fluid. I still faded my brakes at Road America last year. These heavy cars need all the help they can get.
motorhead
Ottawa
2019 Challenger HC Widebody
High pressure and low pressure areas abound. FCA has a wind tunnel, and you have an out of calibration Mark I eyeball. So unless you are Greta, and can see non-visible gases, I would trust the fluid modeling and practical testing.
Thread Starter #43
You bought a goofy looki'n car, what'ya you know. And factory hood pins don't work either! They're just jewelry.:p
Detroit Muscle
Apple Valley
My Redeye had the deflectors in a box in the trunk when I purchased the vehicle.
I have not installed them.
Decay
Astoria
OR
2019 widebody Redeye
I installed them.
Pizza cake!
I have had this thing up and down changing fluids and wheels and tires so it was no big deal.
Thread Starter #46
I installed them.
Pizza cake!
Understood. But the thread was started because I questioned the functionality of them.
Decay
Astoria
OR
Copy that and I have no clue.
I suppose one of the road course members on here would have to do a test with a pyrometer at the track.
I figured when they had this svelte beast in the wind tunnel somebody noticed that there was no wind on the brakes and the one engineer who had a brother with a plastic device manufacturing plant said "I've got a fix".
Decay
Astoria
OR
#48
With all the gadgets and gizmos on these cars I'm surprised you can't see the brakes/tires/rear diff temps.
I've just spoken with the @CDT Rotors people :cool:, as part of the data logging that will happen later this year, they will test with and without these in place and get caliper temps at a minimum.
I'll throw my spin in here......these may not be designed to direct air at the wheels/brakes, but instead could act as a vortex generator and create a resulting airflow that would work to pull air from/through the wheel/brake areas....and no....I'm not a fluid dynamics genius....but I did sleep in my bed last night :p
Motel 6 or your opinion isn't worth squat...
:p
motorhead
Ottawa
#52
As I said: There are deliberate high pressure and low pressure areas engineered into these cars.
Is that the new orange Hellcat?
and I don't doubt your veracity sir :)
I got into an aerodynamics conversation with someone last night....and then my mind went to this discussion....as I've admitted before...weird things pop into my head at weird times :)
Confuzed1
Go Pack Go
#55
Funny this topic came up. One of the things I asked about before I picked up my RE WB at the dealer was if the deflectors were installed or not since I looked in the trunk and didn't see any there. Annnd of course....the sales manager gave me a blank look and had no idea what I was talking about. Car sits so low, I couldn't tell if they were there or not. So I explained to him what they were - just a couple plastic flat pieces that are mounted on the lower control arms with U-bolts on the front that help direct air towards the front brake rotors.
He had one of the service guys jack the car up a little on the show room floor to make sure they were there and they were indeed installed. I doubt they do much at real low speeds, but I can see them directing some air towards the rotors over 40 mph. They probably weigh a whopping total of 2 pounds max. I also asked him to remove the yellow shipping guard for the front splitter and put it in the trunk....guess I'm not one of the "cool" guys. :cry:
#56
You should mount the deflectors on the splitter guard and reinstall it.
motorhead
Ottawa
#57
McLovin
Syracuse
Decay
Astoria
OR
#59
One might say 'Parachute-like' aerodynamics.
Helps when slowing down for corners.
But the brakes won't be so warm...
rayzazoo
Hellcat
#60
With the new belly pan as well?
