Jon's Hellcat
Thread Starter #1,341
Chuck
Auburn
2021 Redeye Super Stock
running a curt tune on E85 ported blower 1300 inj 2,72 upper 10% lower
1028 hp wheel 1014 tq
Happened 3 weeks ago at track at the end of pull impressive smoke show
if I coujld figure out how to post video its inpressive.
Thread Starter #1,343
Wow. 1300s and stock pumps can not handle that boost even with a bap. I went ported and maxed the pumps and dual bap and 1650s early in the year and I think that is what caused the problem but can’t be for sure. That was a 2.85 upper. This car was a Curt car before I owned it and it was being spun to 6750. Which if your car is tuned that high of rpm and that pulley combo I’m surprised it all held together.
i wonder what it is about cylinder 2 tho? Also interesting we look identical. I’m not sure your plan but I highly recommend @Hatermkr for your build. He will be fair to you and talk to you about your build
Brooksville
Someone along the lines have spoke about rods twisting, might have been AJ quite some time ago. I believe Redeye rods and pistons are sub par Jon’s got the good stuff now!
Hatermkr
West bend
2016 helldemon
I was the first to use Oliver rods in these engines
I don’t think you can get a better rod. I did use 625 rod bolts in mine.
The good thing is when you build most stroker engines you use a 6.125 rod witch is actually a small block Chevy rod.
Brooksville
Damn Hatermkr you’re gonna cause some heart attacks using Chevy and Hellcat engine in the same sentence 😃
Hatermkr
West bend
2016 helldemon
Does use Honda oil lol jk
Not made by Chevy. By using a common rod not a bad thing:cool:
If I were building a max-effort engine today with steel rods, I would use only Carrillo I-beam or Callies Ultra I-beam rods, never Chinese garbage. Just my $0.02.
They’re lighter. Meaning less material. They’re made to make redeye power more efficiently, not hold up to mode. Old school hellcats are the best for modding
Hatermkr
West bend
2016 helldemon
My last one had Callies ultra I beam the Oliver rods are a better rod hands down
Like I said, 15 years ago, Oliver is all I used in my own engines. Builders and racers I trust have reported numerous Oliver rod failures in the last few years, mainly since "the thing" happened. I don't know any more details on the cause, whether material quality or manufacturing quality issues. Just sharing what I hear. A common theme is also the physical move from prior location to northern Michigan - "not the same operation".
Thread Starter #1,353
I live in Michigan so using a Michigan rod was a plus for me. I know I talk to some Chevy racers and I told them I was using Oliver’s and they all said very good rod. Everyone has their own experience. I’m happy with the Oliver’s. @Hatermkr is spinning his engine harder than I will and he’s yet to have a rod failure. He’s also used Oliver’s on a ton of his builds.
there are for sure many other really good options out there but the rods are not a concern of mine.
Hatermkr
West bend
2016 helldemon
Your stock rod lost its belly lol
Hatermkr
West bend
2016 helldemon
Thread Starter #1,357
What rod it left no evidence 🤣
Hatermkr
West bend
2016 helldemon
Your rod look like bidens brain lol
that's being VERY kind ^^^^^^^^^^^
Chuck
Auburn
Wish I would of known about him already ordered a new motor and didn’t have a core to build
Chuck
