TIME SLIP CHASER ,SMACK TALKING ,THREAD HIJACKING,HP TUNER , HELLNO THATS ME
heres something to add to the info about my car ,only hpindy knew that I had already addednthe 10% overdrive to my car last monday without any other changes I still have the demon injectors and im running 17 psi and if you would like to see the logs the injector duty cycles at redline got as high as 93 last night but sunday in the 1/8 mile highest we saw was 83 but no always the reason they didn't totally max out was because of the jms and fuel pressures at 89-94 psi my lamda readings were fine and never showed any issues ( curt has seen the logs and even he was surprised it didn't max out the injectors) I did pull 3 degrees of timing out of my pump gas tune and I raced it last night with the original race gas tune I did have the octane at 110 when I got the 9.95 pass I had actually added 1 degree of timing to it but as you can see my 60 ft was bad because I spun off the line ,then I took the 1 degree back out and made the 9.92 pass after waiting two hours to run it again because of track issues and someone getting run over by scooter on the service road it still didn't hook the way I wanted and I didn't launch it as hard as I normally do but I did get it back down on the 60 ft
That's Awesome hellno , The Percolator is kicking ass , & you have some nice goals , so I guess you'll be doing a roll bar soon ? …. & you think the 2.62 will do better after mods ? … you might try the 3.09 first , after flex tune mods then swap it to the 2.62 to get a comparison.
Awesome job there caffeine brother. Mean Cat knows what I'm referring to. LOL Congrats on reaching your goal. I'm glad you finally out 60'ed me.😀😀😉
Looking forward to seeing your progress. This should be good.🍻
I'm heading to the track tomorrow. I will be trying for that 60' of yours. Just not sure it's got it in it. But I said that about 1.50. LOL
yea they are and I just looked at them and they still look like new ,but being mines a v6 it doesn't hardly have the power to spin them over so not any wear issues at all
(v6 has its perks hpindy)
True ...... Very true . I may have to look at the same V-6 you have .
V-6's don't need no stinking roll bar
Jim I have no doubt your car has 1.49 60 foot in it . You car is a unicorn that farts rainbows .
I'm happy to see hellno reach the 9's . It was a struggle I know all too well about .
Thread Starter #366
I will definitely need the 2.62 back in it it’s alrady hit and miss with traction and I’d like have it go through the traps in 5th instead of 6th
Once I modded past a certain point the 2.62's worked. Better for me . But if I ever get the traction figured out I may try the 3.09's again.....maybe
You should have heard me when I saw he got it. You would have sworn my team won a hockey game. LOL
Or at least as if I was there to see him do it.
I was just poking at him because. Well he would've. 😀😀
Thread Starter #369
My 60 ft sucked last night track was so bad
That's the bonus with having an under powered car. It almost always hooks at my track. LOL
Still you must be stoked. You finally got your 9 sec passes.
Thread Starter #371
That's the bonus with having no heatsink an under powered car. It almost always hooks job at my track. LOL
I am and had I not backed it up I would have went nuts
I fixed my post so it looks like I actually speak English.
Thread Starter #373
Unfortunately I have an addictive personality,as the car gets quicker I just want more of it ,at one point I remember saying I just wanted mid 10s it’s madness I already spent a lot just getting it to this point and dropped another 4,000 this week for the next step , it’s like my kids always has it’s hand out for more and I keep feeding it lol
Speed cost money .......... How fast do you want to go
I was going to ask what language that was .
Thread Starter #376
I don’t know how fast is there :unsure::unsure:
Thread Starter #377
I forgot to answer the roll bar ? They didn’t say anything the other night but they definitely saw the run I’ll have to see what tech says next time I check in but I may have to get one eventually even for my own safety
Yeah , if you run in to the 9's once in a while you could get by w/o a roll bar but if you run deep in the 9's & all the time ?... then you'll prob. need 1 b4 long.
If that's the case , you should add another 100 hp. :LOL:
Thread Starter #380
With the power I’m adding 60ft might not matter lol
