Picking up a M6 Hellcat
Thanks for that info. I’m swapping it for the Barton anyways, so we’ll see. I’m 99% sure it’s the bearing though, which I’m hoping Dodge will cover under warranty.
If not, no big deal. I’ll live with it for a bit (not my daily driver) and pull the transmission when it gets warm haha.
Wondering if the dealer will make a stink with the stock shifter removed?🤔
mopar madness
Denton
2018 BMW M5
as long as your power train warranty is in effect you should be good, only issue I could see is if its the clutch itself but it would be slipping if that were the case
A
AeroF16
Phoenix
Thread Starter #143
Yeah I thought about that a bit but not sure how they’d relate a shifter to causing throw out bearing problems.
A
AeroF16
Phoenix
Thread Starter #144
No slippage at all and honestly the noise isn’t all that bad. If I put a piece of insulation below the shifter boot, I’d probably never hear it.
A
AeroF16
Phoenix
Thread Starter #145
Got it up in the air today and went through it. Really happy with how this turned out, the car is in excellent shape and exactly how the seller described.
Pulled the MFERs off and a few small other things the previous owner did (tinted film on side markers, aftermarket center caps, etc.) Dropped the wheels off to get balanced and noticed a couple of the lugs are swelling.
Really happy to find the brakes are in good shape. With only 21k miles I wasn’t expecting them to be bad but you never know.
Called my local dealer to inquire about lug nuts and they wanted $16 EACH! Maybe he was confused but that was a hard pass haha.
Ordered a set of Gorilla lug nuts and Powerstop Z26s all around. Hoping swapping the pads now will increase the longevity of the rotors.
Assuming an appropriately matching driving behavior, absolutely.
Good move on the lug nuts. When I had some PS4s put on last summer, the Discount Tire guy told me the two piece originals were prone to swelling and sold me an aftermarket set. Guess he wasn’t BS’ing.
A
AeroF16
Phoenix
Thread Starter #148
Yeah, I had 2-3 that I could only get the socket about 1/2 of the way on. Wasn’t an issue but it definitely is worth an ounce of prevention. Imagine getting a flat tire in the middle of nowhere and not being able to get those things off.
A
AeroF16
Phoenix
Thread Starter #149
@BULL or anyone else that knows,
I just read through the Barton spring mod Wiki. At the end, it says V2 and V3 are "consistent" with the Wiki. Does that mean Barton had modified those shifters already or that the Wiki instructions are correct for those two versions?
My direct involvement with Barton ended at the end of V1, my understanding of V2 and V3 are angular changes to the shifter/stops. As such, the spring mod I wrote up "should" apply to the newer versions, I simply haven't had the chance to physically check it out.
I'm reaching out to Dave at Barton (owner) to ask about what the changes are between V1, V2 and V3.
A
AeroF16
Phoenix
Thread Starter #152
Struggling with this right now. This shift boot is not going to fit all the way over the handle and seat in that groove, not even close on mine.
What am I missing?
What am I missing?
I stuck with the O.E. stick on mine.
A suggestion would be to soak the boot in hot water for several minutes.
Just the tip (so to speak)...
:unsure::p
Look at about the 6 minute mark:
A
AeroF16
Phoenix
Thread Starter #157
Well I got the Barton installed today and I’m happy to say that the noises from the throw out bearing and transmission are significantly reduced and it now sounds normal to me.
It’s not the shifter though, the previous owner just didn’t put the rubber seal on correctly that fits into the metal plate that bolts to the floor and seals between it and the shifter assembly. My guess is it was close and eventually just worked it’s way off over time.
I didn’t do the spring mod but I’m happy with it how it is, the force going into 5th or 6th doesn’t seem overwhelming to me and rather natural. Left the shift boot off for now so I can spend a little more time driving the car and get the shifter position dialed in.
Sorry if you said this already, what version was yours?
V3?
A
AeroF16
Phoenix
Thread Starter #159
V3?
Yes. It’s stiff but just doesn’t bother me. I could see how someone might not like it though.
We’ll after trying to remove the studs on that BMW I’m sure this was a walk in the park. 😂
