UPDATE! "Water Spots" - What is the best way to remove that is not abrasive?
Pulled this thread up;)
My dad has well water and I had a black truck years ago that would get water spots from the sprinklers. I tried different things to get them out little did it help. There was one thing that worked very well.....rain! If we had a good rain they would disappear
Thread Starter #42
UPDATE:
As I mentioned in the What Did You Do With Your Hellcat Today thread, I finally got the spots out.
Maguires iron remover, water spot remover, clay bar.
I did not use the clay on the glass so there is still some spots visible. Next wash I'll clay the glass.
A lot of effort but it worked without buffing. Very happy! :D
Thread Starter #43
Holy wood stack Batman.
Fwiw, a friend of mine is a professional detailer. He recommends a 50/50 mix of water and vinegar to remove water spots. Obviously clean the area first, wipe with solution until spots are gone, then a fresh coating of sealant. I've used this technique a couple times with great results, the water spots come off pretty easy too.
Also just fwiw...this sealant is really good:
https://www.amazon.com/CARPRO-Reloa...prefix=reload+car+sealant,aps,176&sr=8-2&th=1
Thread Starter #46
I tried the vinegar, mix, full strength, did nothing. It sure felt like the iron remover and water spot remover were very acidic. Then a quick light clay finished what remained. I did not expect it to work as well as it did. After, I put on Grotts "ceramic" wax.
For the next 2 days, I had water beading up and rolling off my hands! (I did not wear gloves for any of it.) I think I will when I do the 170 next time we the right weather.
Thread Starter #47
What you see it next years indoor stack, the empty space next to it is this years. Then there is the wood in remote shed which holds about 1.5x the indoor.
Hey, winters here in NH are long and hard like..... The trees...
Decay
Astoria
OR
2019 widebody Redeye
#48
In Clatsop county you are judged by the contents and neatness of your stacked firewood!
Gotta be Hemlock and Fir and ALL the same size and no listing/leaning stacks!
Thread Starter #49
Do you feel the same way about your gas for the HC? :ROFLMAO:
GBLWRMR
South
2022 Super Stock
#50
I use this on my black cars when caught in the rain. All ceramic coated but still spot and difficult to remove. I use sparingly as directed and works incredibly well without the extra elbow grease.
Car Pro Water Spot Remover
CARPRO is a really good brand of products, mainly used by professional detailers.
You need to be careful with that stuff, while it does work for many situations, it is acid based !!
Be sure to follow the instructions to the letter & DO NOT let it get near your stripes, any vinyl stuff or rubber seals, any flat paint or the grey plastic trim !
GBLWRMR
South
2022 Super Stock
Agreed! Works great but wear gloves and use wisely.
Thread Starter #54
I used another brand and no gloves, and my hands were really clean after! :ROFLMAO:
And if it dries, the only way to remove the residue is with more spot remover!
#55
Keep yer car outta the rain...problem solved
Thread Starter #56
I see an "Ignored Member" replied to my thread, sorry everyone.
