GForce Engineering fully-fabricated 9” IRS With modified cradle
Well the car is “done”, other than an alignment, so it is just a matter of waiting for the good weather to hopefully show up in a couple of months.
In the meantime I decided to go ahead with a mezzanine project I have wanted to do since we moved here about 2 1/2 years ago. We live in a barndominium style home that was built in 2020 and although it was framed in during construction, there wasn’t an entrance to the shop from the second floor, which is our main living area, so I decided to go ahead and finish it.
So although this isn’t a post about the car it is the car’s place.
View attachment 177893 View attachment 177894 View attachment 177895 View attachment 177896 View attachment 177897 View attachment 177898 View attachment 177900
Awesome garage...who's the rocking chair for...gramma ???
Ta2ude
Fuck Carney
2019 Redeye Widebody Challenger
Thread Starter #102
Thanks
The rocking chair was a leftover from my mother when she moved into a retirement home. I actually put it on the curb a few weeks ago after moving it around my shop for 2 1/2 years and it was gone in about 10 minutes, so some old fart probably has it on their porch now. lol
Ta2ude
Fuck Carney
Thread Starter #103
The weather was nice yesterday so I put the collision insurance back on the car and took it for a test drive . It was the first time I had driven the car since the modifications and I have to admit I was a little nervous, but I wanted to see how it drove before it went in for an alignment. Thankfully everything seemed fine and it drove very well.
The only “issue” I found was the differential had a slight whine on de-acceleration. I did a google search and reports varied but apparently it wasn’t uncommon for people to notice this with the Detroit Truetrac. I will get the technician to look at it when he does the alignment and decide if it needs better adjustment/alignment of the gears.
Other than that it seems like everything is ok for now and I should be good for testing at the track May 9th.
Unfortunately Mother Nature is up to her old tricks and we got snow again last night !
Ta2ude
Fuck Carney
Thread Starter #104
If someone could provide a link or direct me to a post with alignment specs I would appreciate it.
Thanks
Factory specs in the front. Positive camber in the rear. I ended up with +2 degrees. Ran 1.25 sixty with that on a 315/60R15 Radial Pro. Key to straight line stability is zero toe in the rear. Make sure that if there's any error, it's to the inside.
Ta2ude
Fuck Carney
Thread Starter #106
It looks like the weather is finally on our side. Just figuring out where to install the etrack and the car goes in Wednesday for an alignment. Weather permitting I have been invited to a private track day May 9th !! IMG_7932.jpeg IMG_7928.jpeg
CPO Super stock
westminster
2021 Superstock
looking forward to some time slips. Have fun.
Ta2ude
Fuck Carney
Thread Starter #108
So I actually found specs that are supposed to be “optimal “ for my Gforce modified cradle set up and I had my car aligned today. Everything seemed to work out fine other than a possible u-joint that is failing and the likely suspect for the noise I was hearing. So for what they cost I am just going to replace the u-joints and hopefully that issue will be solved, but you never know. IMG_7940.jpeg IMG_7941.jpeg IMG_7936.jpeg IMG_7937.jpeg
Ta2ude
Fuck Carney
Thread Starter #110
So I decided to replace the tensioner and idler pulley with the Metco product as I did notice that although the bearings seemed ok it was visibly obvious that the belt had been slipping on the pulley as seen by the pictures below
Ta2ude
Fuck Carney
Thread Starter #111
The Metco pulleys not only looked a lot nicer they were considerably lighter. IMG_7974.jpeg
Ta2ude
Fuck Carney
Thread Starter #112
When the belt was off I took another short video to try and show the noise I was hearing that had me concerned about the bushings in the snout. If you watch the video you can hear a definite “clicking” sound when I move the pulley back and forth.
I am wondering if this is normal or a sign that the bushings inside the snout are wearing. I think there are 6 or 8 plastic bushings inside the snout, that drive pins go into and I believe the noise is an indication that they have worn and are now sloppy.
I was wondering if anyone could confirm or alleviate my suspicions.
Here is a link to the video.
Thanks
https://youtube.com/shorts/RMSPGcaTryI?si=dMtPTJHdGosZe76p
Ta2ude
Fuck Carney
Thread Starter #113
FYI I double posted this, hopefully I haven’t broken any forum rules or etiquette.
We got no rules here we're either tryin to learn somethiing..or have a few laughs
Ta2ude
Fuck Carney
Thread Starter #115
Here is the video that lead me to believe I might have an issue. If you click on the link you can watch it on YouTube.
Ta2ude
Fuck Carney
Thread Starter #116
A couple updates, between bad weather, a case of pneumonia and other commitments I still haven’t made it to the track.
I didn’t like the noise the differential was making so I pulled it out again and had it set up properly, we found the backlash was definitely out of spec and we now have a very nice pattern and proper setup.
I also decided I didn’t like the groove in the aluminum driveshaft and rather than trust it not to fail I ordered a carbon fibre driveshaft which should be here early next week.
Where was the groove at in the driveshaft?
You probably posted it but.......let me know anyway.
Ta2ude
Fuck Carney
Thread Starter #118
The groove was right at the back of the rear heat shield. It’s hard to measure exactly but it’s about .015” deep I would guess.
View attachment 183120 View attachment 183121
Everything is so close together under there. I had a Al Driveshaft with a grove that broke through at the top end of the track going 135mph. It was so weird because I got off the track and around to the road back and I hear this Ding ding ding, driveshaft still spinning and engine won't shut off. Luckily I had a bunch of guys help until Josh@ HHP could get over to me. I had so much help, Josh said it was easiest time he ever had loading up a non running car onto a trailer. He got to sit in stir ;)
Any way the driveshaft broke up toward the front and the spinning hit, I think it was the input shaft on the Trans, so lots of damage. :(
Ta2ude
Fuck Carney
Thread Starter #120
That’s why I didn’t want to take a chance with this driveshaft, if it broke it could cause a lot more damage than the cost of a new driveshaft.
I called GForce today and my carbon fiber driveshaft “should “ ship out tomorrow, so I should have it by Monday and I can finally get this thing back on the road. I added another heat shield by the front of the driveshaft and am getting some heat wrap as well to cover some of the exhaust. I still plan on street driving this car and apparently the carbon driveshafts don’t really like too much heat, so hopefully the wrap and shield will be enough to prevent issues.
There is a Mopar Fest at St Thomas Speedway this weekend, which is about an hour and a half away from me, unfortunately I will have to be a spectator once again but it should be a fun weekend anyways.
