P00EA IAT Sensor 3 Circuit Low Bank 1
AMRCN HP
Normal
2019 Billet Silver Redeye
Question - I've received this code along with the dreaded P1620 on a few quarter mile passes lately. Since I'm pulling the blower to install spacers/blanket I plan to replace the offending TMAP sensor.
Can anyone confirm which of the 4 sensors "sensor 3 bank 1" represents?
When I look up P00EA, it references the sensor on the driver side, middle of the blower (intermediate TMAP). However, when I looked up the supercharger removal procedures the sensor on the front of the blower on the passenger side is referred to as 'bank 1'.
Want to make sure I replace the correct sensor.
Paul...
JDG
Ph
AL
Hellcat
AMRCN HP
AMRCN HP
Normal
Thanks, I hadn’t seen that diagram.
However, I’m still not sure which of the 4 sensors the code is for... looking up the DTC, it calls out the intermediate TMAP sensor (#2 above). The ‘bank 1’ sensor is called out as #1 in the diagram above. And the Dodge service manual refers to #4 above as the ‘bank 1’ sensor.
I’m so confused...
JDG
Ph
AL
Hellcat
I’m so confused...
Well they are something like 40$ or less a piece. Might just want to change all of them so they are of equal age. Would save lots of headache trying to figure out which is bad when one or more may be acting up. I would pull different codes indicating a different sensor occasionally so upgrading all 4 is my current route.
AMRCN HP
AMRCN HP
Normal
Interesting - were you also throwing a P1620 and dumping boost?
Its possible I may have logged a different sensor/code once or twice - may just be easier to replace all.
Paul...
JDG
Ph
AL
Hellcat
Paul...
I had P00FA/FB and a few other associated ones I cant remember. Im pushing to much boost for my sensors is my problem though. You didnt mention your mods, but my issue goes to making over 18psi on a 2 bar sensor.
I will be paying close attention to this as well. I do not currently have this issue but I'm trying to figure out which sensors are logging which parameters in HP tuners and I have an 18 plus car and some seem to believe that the 18 and newer already have 3 bar (I'm making 19+psi on a 2.5 with no codes)
JDG
Ph
AL
Hellcat
Thats my understanding as well. I ordered 4 oem demon maf sensors, just working on a tuner to get them squared away.
AMRCN HP
AMRCN HP
Normal
Have heard this as well.
AMRCN HP
AMRCN HP
Normal
I'm currently running a 2.85/10% combo so am probably sitting right around 18psi. I only get the code near the top of 4th gear, which does make me think it could be max boost related.
Maybe I should replace with the Demon TMAPs instead since I'm planning to go to 2.65 shortly.
Diagram says "Theory of Operation". We're not really sure how it works LOL
JDG
Ph
AL
Hellcat
Well they could prob make it work if it wasnt a theory.
JDG
Ph
AL
Hellcat
Demon sensor part number, dont know if it matches 18+ sensors.
AMRCN HP
AMRCN HP
Normal
Found this which appears to confirm its the intermediate TMAP. I’ve already got one inbound, so may just replace and see if that takes care of it for now.
Good man. I'm always down for only replacing what broke.
AMRCN HP
AMRCN HP
Normal
Talked to Mike via email this morning; he's still using the Hellcat sensors on the shop car with a 2.65/10%. If it's good enough for him it's good enough for me.
Now that I know which sensor to replace I should be good - prolly just got a bad one.
Paul...
