Recommended spark plug gap?
Hey everyone, always so much good info here. I am having my spark plugs replaced on Thursday, 53k miles on the car and it still runs fine. I will be sure to share pics of the OEM plugs that we take out.
So I am installing the factory Bosch iridium plugs SP196724AC and I am having it done at the dealer so they will obviously know the OEM spec, - but I just want to have the proper info as a backup. Car is still stock for now.
Any thoughts? @16GoManGoHC2 ??? @Speedy! ???
Subbed
Wizza
Stafford
VA
Different setups can change these values
So I think my redeye stock/sea level makes ~14.7 psi and I live at 5300+ elevation so my car only makes ~12.5 psi.
I ran .028 at 22 psi when I put my whipple on. When the car was apart last winter I went to .025. I ran .028 with my Mustang also at 22psi.
I went .021 this time around for good measure. I was making 17 lbs of boost, will be making more
Also run e85
Car is stock, plugs will come pre-gapped to .032". That's what I'd leave them at.
AGREE with @Speedy on above, .032”
Especially if the stock plugs at stock gap gave you no issues for 53,000 miles and your still stock no reason to change what has worked good so far. The bigger the gap the more molecules of mixture ignite which makes for quicker flame propagation and better performance
For stock boost levels, yes. What plug gap do you run with your boost level?
At 30 psi of boost when I ran the 3.8 Whipple I was running .018”, still set there at 25-26 psi I’m running now with the 2.7 IHI blower.
…and if you want to see what 6 year old 53k mile spark plugs look like on a stock tune redeye:
I don't see anything wrong with those plugs other than you need to romp on it a bit more often :LOL:
I don’t recall my stock plugs being Bosch but that’s a 2015 regular hellcat
Surely you jest! :ROFLMAO:
...Shirley...
2ndgen
Orem
52k miles, stock 2017 HC plugs:
