How much tire is to much tire
Chuck
Auburn
2021 Redeye Super Stock
As the title states is my question
Fitment issues..generally dictate how much is too much
Purely size based question? This has been our battle since the HC/RE came out, what tire/wheel combination can fit without undue rubbing and/or mods...
Does a dead-blow to the rear inner wheel well bother you? Drilling holes and moving plastic rivets work OK in your mind?
How about how far out past body edges?
Phillips Flares ok?
All of these questions equate to different sizes.
Deano
Law Enforcement
Roy
2019 Challenger WBHC
Even going to maximum fitmet, it is not enough.
Phillips Flares ok?
And
Phillips Flares ok?
would never take a drill...hammer..or any cutting tool to my cars...EVER
Agreed, unless you are only doing moderate GT driving in a canyon, then O.E. is enough.
And
Exactly my point, for you ~295 is about the limit, for others on the other end of the spectrum, 325, or even 345 has been shoved in the hole, but it's a VERY different mentality.
And
the Phillips flares...and 1/4 in. spacers..(I dont race.. spacers are fine)..work awesome for my triumph oversize rims and tires..look great..and fit great..
Got nitto DR's out back...can't tell ya what size...(you would think I should know)
Well ya made me go out to the man cave and check the sizes...(nitto p315's)...I remember when ordering the triumph wheels..we had a discussion bout offset...it's not stock..(there still 20's)...but a deep dish that looks spectacular...
S
315 35 20 on the back of my Challenger with a very thin spacer. Clearance is perfect and therefore that was the perfect tire for my car.
Same set up I run on my HC...and with the Phillips flares...it looks killer
Chuck
Chuck
Auburn
Having trouble getting this car to hook up at the track the only way to get some traction is to run my MT Et drag bias 29.5x10.5x15 running the Et Pro drag radial 315x60x15 can’t get them to stick I’m running a little over 1000rwhp
was thinking about going with the ET Drag bias in 29.5x13.5x15 on a 12” wheel
Biz originally got with Bill? (been awhile, not sure of the Phillips flares owners name) And created a wheel with correct offset to fit Challenger's with the flares installed.
315 40 18s stock Nitto DRs on mine
Billet Train
Toledo
315 50 17 m/t's and Phillips flares
