Nearly 40 years on Sport-bikes learns-ya the same lessons. You don't have to drive/ride fast, all the time. If ya do, it'll git ya.
Correct, you don't. But if not driving fast I might as well drive something else.
...sell yer favorite car you say...are ya fuckin crazy...take some time..go to NYC...watch the Yankees play...go to Key West...lie on the beach...talk to people..do something....but in the name of all things Holy...DONT sell yer car..:rolleyes::rolleyes::rolleyes::rolleyes:
Hmm. Go to New York, watch sports, lay on a beach. Any of those makes driving off a cliff side seem appealing in comparison. At least then I'd get to kill myself (as opposed to in NY), or die by boredom (sports, beach).
But you're kinda right. Today my girlfriend took her RSQ8 to town (some 200+ miles) and really enjoyed it. "Doesn't feel fast at all...don't know how I got up to 90." she said. Last time she drove it was probably in October. I could keep the 'Cat and only drive it very occasionally. Or even not at all...it still looks great sitting still.
I drive fast, at the dragway and Land Speed Trials. Very exciting! And knowing what the car can and has done, it is very cool drive slow around town! Nothing to prove. Just a little tire slip on the hgwy entrance ramp at 70 or so, otherwise slow and cool!
Alright, but without a town to drive slowly in, and with no highway onramps, that basically leaves roads that are fun to drive fast on. No road course tracks around either as far as I know.
It'd probably be smarter to go to Radford once a month or so and get the fast out of my system that way.
Finally got someone with a brain to look at the car. Well there was a recall for the cats and 02 sensors several years ago that I elected not to have done. So the left bank cat failed internally so bad it bent the 02 sensor. I’ll send pictures shortly. Both cats and sensors are being replaced under the recall. No,@Jon-MooredPerformanceLLC they are not flashing my PCM😉.
I skipped that recall myself
:unsure::unsure::unsure:
Cat got an alignment + brake fluid flush/change yesterday. They tried to fix the weird 'rubbing' sound @ low speed coming from the steering column but no joy on that :(.
They applied the TSB that called for lubing the boot & steering shaft where it meets the firewall. The Tech agreed that the noise was coming from inside the car and said most of the time that fixes the issue. He suggested I drive it for a while and give the grease time to work itself in & see if that makes a difference. Next step is to tear into the rest of the column, tilt pack & wheel - he didn't seem too eager to go down that path & neither am I. At least they didn't charge me anything for the effort !!
I've got that rubbing sound too, had it since day one.
Mine started a while back & has gotten worse. Researching it, turns out to be a common issue across model years & even with other brands. The universal solution seems to be to load up the rubber cap & bushing where the shaft meets the fire wall. The whole assembly looks like a toilet plunger :LOL:
Tech said mine was pretty dried out (FL is a beotch on rubber things), so it might get better as the grease works it way into everything down there.
Bowlerguy92
Then you wait for nightfall, hop on those roads and you send that shit. If you see blue, cut your lights and push the gas down harder until they're gone.
Or, go to Radford. Ya.
Driving at night isn't ideal here. That's when the elk and deer are out and about, plus they're much harder to see in the dark.
Not that I've waited to see any blue lights, but when the Valentine tells me that there's radar signals coming in from the rear I get on it a bit more. So far they haven't caught up with me.
Here’s that cat picture. I didn’t get one of the bent O2 sensor. A used but serviceable one on the top and my bad one below.
23 Challenger Demon 170
At least that Kitty will live to fight another day! Great news and it’s covered under warranty I hope!
View attachment 163445 View attachment 163446
Happy it will be covered for you! All I will say is, the only good cat, is/a ______________ (I'll leave it up to each reader to fill in the blank ;))
All I will say is, the only good cat, is/a Granite standard body
Filled it in for you.
@DGatzby
I don't recall exactly, do these look anything like your cats that shyt on themselves???
I don’t know. These are covered under the recall so I assume so.
Covered under a recall from several years ago but still active.
I never got mine done, makes me want to disconnect and bore scope them to see what they look like.
