Jon's Hellcat
Thread Starter #1,181
Oem broke that functionality for model years 2018-2021 Hellcats and Hellcat variants. For 2022, it seems to have started working again.
Interesting. My car is the forth I have seen not work. I haven’t had the “opportunity” to see a 2022 go above the pw yet.
such a nice feature.
but let me ask you this as I was thinking about this last night. COT on a stock 18+ opens the bypass valve when inj pw is met so in stock form it appears to work. Any thoughts on this. I was wondering if it’s an hp tuners issue. I have been seeing some really odd bugs lately on some OS versions.
How about human issues??
Have seen on a few cars doesn’t always work
Weird, Hopefully it stays working on mine, it is a great fail safe for pump failure, etc.
Why 2 pumps?? What the factory guy told mae.
Mr Clarksville,,, how's the river and bridges treatin ya?? Sum fine shine and gals come out of them hills. Snow melted yet?? No, the stuff cumin out of the sky. The Cumberland has sum bad ass snatch fish in there. Not the hospital either.
Good to see you back. Still making the adjustment. It's not the Tennessee I left 32 years ago for sure. Having second thoughts, you can bet your ass but I'm in to deep now so it's swim or drown.
Yo Bro,
I really liked Clarkesville and if that copter pilot from the Ft. If she had pushed the notion a bit harder. We, we, would still be there or sum wares the Army wanted us and who to be. Butster that waz in the 80s. When I had 1 of my choppers up there from Chat town. I had friends at Austin Pea and helped build the boiler at the Zinc Plant. That waz fun except the snow. It drove me and the Duster away. Good luckster.
Thread Starter #1,187
I just realized my car on one fuel pump is faster than @RGPIII with 3 of them :ROFLMAO:
oilburner
coboconk
I thought redeyes got 2 or has one of the 2 crapped out.:unsure:
Thread Starter #1,189
I think one took a crap after a long life at 22v
I still want to know what’s going on with the fuel pressure difference between stock hellcat rails and Redeye rails on a hellcat
Says the guy with 2 pumps from the factory whos running BAPS to burn them up faster. don't you have more money to throw at that thing to stay 1 tenth faster than my mostly stock outdated base hellcat?? :ROFLMAO:
ok ok lol, I’ll move doing the test up the list as I would like to know as well as using the ported RE fuel rails my WOT trims where more even bank 1 to bank 2 which tells me it’s either a higher pressure then thought or the RE cross over tube to the driver side flows more than a ported Hellcat one does. Most likely it’s both of above, bottom line is I’d like to go back to the RE rails
I see fuel pressure dropping off up top, I just want to make sure it’s not actually dropping off or it’s just flowing so good that 80+ psi on the top end just isn’t needed to feed the injectors with the RE rails
Wasn’t trying to poke you @16GoManGoHC2 . Ok, maybe a little… lol
Heat it up wit a tourch and sea how fast it moves.
Better than boiling your fuel through your hot triple pump system you have
Also I’ve still been faster than you on baps
Burn
Interesting
Thread Starter #1,200
look we have a new bully on board with the built redeye guy picking on a stock 2016 hellcat! :ROFLMAO:
Indy is a pump gas car running low 9s 😉
