Looking at open haukers with the air dam. Have a good lead on 2022 tilt for car hauling that checks all the boxes, winch, small slope, epoxy frame. Just waiting on vin and gvwr. Also @Jimmy N. I towed to VMP with a friends suretrac. It was fine, truck barely felt it. MPG was def poop lol.
I'm thinking the basic load out kit. Empty jugs (pump e85 will be had). And my personal belongings and Ill be fine.
Air dam power bed open hauler is great depending on distance. Had the HC trailered on one for 400+ miles when brand new and everything was perfect (loading and.unloading were key concerns). Obviously, rain / hail /overnights wo protection can be issues, but these were not issues i had to deal with.
I need an ac unit and spacer heater now. If anyone wants to buy me a present 🤣 it can just be a portable ac unit I’ll just vent it through the floor
Enlighten me, what's wrong with Tractor Supply??
I tend to go to more local centered farm and equipment stores. Not saying anything wrong with it, just kind of walmart for country folk.
I thought it had a/c
hell on wheels
Saint Paul
Dodge SRT Demon
Hell, that is just a great shot. Everything clean, orderly, early in the morning. Good drag racing in a nutshell. Thanks for sharing.
And of course, an awesome trailer.
hell on wheels
Saint Paul
Dodge SRT Demon
4E19B1E8-CF77-4F49-B854-9A66B50B8CAE.jpeg 0EE62647-DF12-4F82-B251-84FD3E8EF486.png ET Bracket Racer
Thread Starter #250
Added a mod to the battery system. Never got around to running the hard wires under the truck and fuck all can’t be bothered to now with the Hellcat in eternal slumber. First cleaned up the wiring and finally put the lid on.
immediately pulled the lid off to start a project
the kit can be found here) https://a.co/d/9aPQNno
Attached the PWM module to the lid with outdoor velcro:
Spliced in a battery connector to attach to the existing one. Did a test since it was getting dark out. Tested load and charging with a spot light.
the closed it all up right now its in a temporary spot till i figure out where i want final location to be
going to check voltage in the am and the chrck again at end of day
in sun its pumping out 21v in the dusk hours 14v and as expected nothing at nighttime
Nice! Do these little solar cells actually work?
Thread Starter #252
Thread Starter #253
temporarily moved the panel to its final resting place. The PV cell was putting out 12v easily.
Going to let it soak for a bit. If I like the voltage increase then ill velcro attach and let it be all summer. Real test is when the winch goes through a few cycles.
Thread Starter #254
46 minutes ago batterY was at 12.66, just checked
To answer your question @Unholy707 … yes.
Is that charge controller a good match for the battery type?
Thread Starter #256
Yes. It allows you to select your battery type. Sealed, agm, flooded. Its a hell of a controller for the small price.
I've had good luck with Renogy controllers. One of them even lets me pick between 12 and 24 Volts.
Thread Starter #258
Final wire up.
Thread Starter #260
Do you know if it peaked at around ~14.5vdc?
It did not, even my 3amp battery tender keeps it at 13.3v. An alternator pumps out way more power than these devices.
