Sign Up! To view all forums and unlock additional cool features
End links are the same as regular Hellcat. What you are forgetting is the Wide Body cars have way more negative offset wheels. Even 17's clear when the correct wide body offset is used.
Do you no by chance what is the difference in off set is on the wheels for standard and Super Stock I have a few sets of 15 incnch wheels that I used on my 15 SRT
Narrow Body is + 18.5mm, wide body with Holeshot wheels is - 4.5mm. Did you mean to say 15"? Because 15 inch needs to clear the barake caliper as well as the sway bar.
Clearing the sway bar has more to do with BackSpace than offset. BackSpace includes the width as well as offset and it is the final answer. To give you an idea, on my Super Stock I run narrow body 17" wheels on the back when I race for a PB. They are 6.5" backSpace and they barely clear the sway bar. Probably 3/16". But they DO clear.
I have my 15” brake conversion that I took off the 15 SRT Challenger was hoping that it would work on new car but that will more than likely be next year need to figure this new car out first
Thanks for your help
Chuck
There is way more to see there if you know what to look at. There is only .03 difference in our Dial ins. It was staggered .500 pro tree. My 3 Amber Lights are already off and I have rolled completely out of the beams. I am not 100% sure but I am thinking his Green light is on (as well as mine). I cannot see how my Ambers could illuminate and go off in .03 second. So My assumption is that both mine and his Ambers have come on and gone out and I have rolled out of both my beams, and both his are still on. Easy win.
I never saved any of the slips. But you made me go in tha app and it is still there. I am pretty sure this is it. The position of the cars and the dial in's and my (Tim's) car number match. Well, They are using MY car number while I was racing his car. I was told it was something to do with the Ladies in the Tower getting all confused and therefore riled up! LOL
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
