Does Redeye have Demon axles and drive shaft?
firedude
YUMA
I have read so many different responses on this. Would really like to know before putting some sticky tires on for track use. Anyone know for sure? Consensus seems to be only those with 3.09 option.
Yes
cole3986
TBD
Same axles and shitty shaft
I can not say for 100% certainty if the axle ratio option undoes this, but I don't think so.
firedude
firedude
YUMA
Thanks for responses. I thought the shaft was much better? If CCI ever starts making them again I would get one.
cole3986
TBD
Shaft is terrible, go into the 9's and boom. Replace the shaft, put a brace on the center section and send it.
firedude
firedude
YUMA
I do have the brace. Waiting on a good drive shaft. Not sold on what’s out there right now.
firedude
firedude
YUMA
Confirmed today that driveshaft is indeed the same as Demon part number. 53010846AB.
Inrfire
Omaha
NE
So for us non hp adding fiends that have Redeyes and are staying stock, we should have a pretty good safety margin!
firedude
firedude
YUMA
Time will tell.
Inrfire
Omaha
NE
Sheboygan
2016 Hellcat
So, if you have a new Redeye with a factory 2.62 rear gear, does that car come from the factory with Demon axels??? and is the center section as strong as the Demon???
All redeyes have the Demon axles, even with the 2.62 rear.
TrackDay
Great White North
2016 Dodge Challenger
I believe all WB cars have the Demon axles (back to MY18), not just Redeye cars.
2fast4u
Edwardsburg
That is a real plus, did not know my 18WB came with Demon axles...thanks
SunnyS
Siesta Key
2019 Hellcat
Got the Redeye home yesterday and put it on the lift. 0928190603_HDR.jpg 0928190610.jpg 3:09 gear option shows the 846 driveshaft and 799 AA gear that is the replacement for the 497 Demon axle
