Performed a magic trick and made my stock intake disappear and a JLT appear in its place.
This thing is loud as hell now, no complaints. Can hear it screaming, made a few heads turn on the strip. Obligatory post of Max, cause he’s a good puppers.
Diboblo
Riverside
2015 Dodge Charger Hellcat!
Installed a one piece drive shaft cause I already broke the carrier bearing in my second one. FCA should be sued into high heaven for the design. It's garbage. Since there is no slack in the drive train anymore she thumps harder when you request all the bald eagles from the pedal.
Went for an early morning 100 mile round-trip drive today. Had a couple 50-110 mph blasts. Stopped for breakfast along the way. Hellcat never disappoints.
Description of everytime I get on the freeway. This is no lie (as long as no kids with me).
Dog looks like he has no legs.
Sometimes he is one with the grass. :) He has all four legs, he lets me know every time he tries to sit on me and pretend he's a lap dog.
Fine tuned/alignment in the rear. Got the AAD stuff pointing forward, nearly flat camber. Then picked up some dinner, it looks better now. The lower and lower the sun gets, the better this Octane Red looks!
Did this.
Yes, bragging.
At 6'-6" tall, this ain't easy (for me).
Thanks to @Mean Cat for giving me all the info for a clean install!
Nicely done. Taking the extra time not to hack up the trunk liner makes for a really clean install.
Did this.
Yes, bragging.
6' 6" I feel for you. I'm at 5th grade height which I'm not too tall for anything and tall enough for everything else:LOL:
Made more passes at the track today:)
The AAD drag pack kit came and got the new front skinnies mounted up. Now need to make time to install all new rear suspension parts.
Take it you stopped by AAD at Moparty :)
Would have made install SO MUCH EASIER!
Yeah but did you get to 131 MPH? :p
Repaired the pinch weld do to the damage done jacking like a rabbit at the track to put front skinnies on. Then added some lift pads as I don't want to have to deal with the sound of metal breaking/bending ever again while on a jack and having a mini heart attack because of the pops.
Straightened out the pinch weld, it was all fuckered...
Trimmed some plastic so it fit.
Loctite cause fuck you backing out set screws, that's why...
Admire your handy work...
Test.
Should have done this right away when I got the car but now it's good to go. No problems at the track anymore and won't have problems at the house either. best part, can be used with jackstands now as the load is distributed.
