So if I’m changing out the brake fluid in my M6 car…
Does it include the clutch fluid being swapped out? What I mean to say are there two different processes? I did the rears and ran out of time time so I’ll pick it up tomorrow. I’m swapping out my 8 yr old oem with DO4, eventually finishing with Motol 5.1. I’ve still got to figure how to get my scan tool to activate the abs solenoid to get that fluid r&r’d but I understand that’s done after the bleeding anyway. I’m power bleeding them with air btw. So I guess the question is how do I do the clutch fluid? Btw, only 6.5k miles on the car but the fluid is discolored.
F1DE7DDF-48E1-4D50-8E28-6FE6EA32BA81.jpeg 42FD33E6-E9E8-419C-905B-B5FA41B88B09.jpeg CD3BF2D6-0930-4108-92F5-9563EB17E228.jpeg
View attachment 97715 View attachment 97716 View attachment 97717
Did you bleed from both bleedscrews?
If only doing one screw, bleed from the outer screw?
I sure don't like that milky nature of that fluid, is that the O.E. fluid, or have you bled it once already with the 5.1?
Also, breeze thru this, I wrote it. It will give a sense of fluid required.
https://www.hellcatforum.org/thread...ystem-fluid-flush-or-fluid-type-upgrade.3160/
...the clutch is self bleeding.
Good am Bull. Yes, I used the Wiki page, very helpful, thanks. It is the original oem fluid and yes I did bleed from both inside and out and am wondering about the fluid in the line going to the tranny. I know the master cylinder serves the clutch, however I don’t recall anything in that post about the fluid in that line. Should I detach it at the point where the cdv is, have someone in the car pump the clutch while I observe the color change in fluid? I guess the time to do it would be in between the front calipers? Thanks.
