- Member ID
- #1100
- Messages
- 672
- Likes
- 929
- Likes
- 132
- City
- Go Pack Go
- State
- WI
- Country
- United States
- Vehicle
- 2019 PCP Redeye Challenger Widebody
Hey all. 2015 Kia Sportage, about 60K miles. Brakes were changed (all pads/rotors) about a year or so ago. Up until now, they've worked just fine. But now when slowing to a stop, or even at highway speeds if the brake is lightly applied, I get a slight pulsation in the brake pedal.
So I naturally assume it was a slightly warped brake rotor. I bought the rotors and pads off R*ock Auto. I got the medium priced ones, not the cheapest nor most expensive. Anyways, I took each tire off and spun each rotor to see if it looked warped. Found nothing as they all seemed to run true visually. Then I mounted a dial indicator to measure the runout on each rotor on the outside face of each rotor. The most variance I measured was only .002 to .003..... which is little to nothing. I expected the issue to be easy to find, but of course is isn't turning out that way...
-Anything else I should look for? Otherwise I'll take the thing to a shop and let them deal with it.......
