Push Starter Button Not Enabling The Starter Motor To Engage. Advice Please
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Can you shut the car off via the button after doing this?
I took it as referring to the park sense system which is unrelated to the trans. There's also the "Transmission not in park" message that would mean what you're saying. That message would come up when trying to start the car if it wasn't in park or the park gear release lever was pulled up.
yes it is an A8 and the car does know that it is in park. The button works as you would expect save churning the starter motor.
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
@Lord Hellcat is your PCM flashed to an aftermarket tune? If so, I am sure you have tried, but re-flash it??
yes we also re-flashed the tune as well just in case
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
So this would be the fuse to pull to prevent theft when parked?
yes, that would work really well unless someone knew what they were looking for.
There are 7 relays in the fuse board that are all the same so they could take one out of another slot and use it but they would have to be very clued up
stonewall
Conway
2017 Dodge Hellcat Challenger
Dead Battery's seems to open a can of worms with these things. Mine died and then the AC would not turn on afterwards. In mine it blew a relay, I assume from a voltage spike when the battery was re connected. Good luck with this, and please let us know what it takes to fix it.
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
Yep, I don't think it helped sitting idle for nearly 10 months. I keep a CTek charger attached but the battery still failed, well it is 10 years old. Liam is popping over to check the readings on the RF hub with regards to brake switch and key etc. Rest assured I will keep you all in the loop. It was great taking the car out for a spin yesterday. I had forgotten just how bloody brilliant these Hellcats are :)
Lilschmied
Nowhereville
Stupid question, did you check the 30a fuse in line after the relay?
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
yes, all fuses in the fuse board both in the engine bay and the trunk were checked
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
So Liam popped over last night and carried out some more tests.
Using a snapon diagnostic tool we found that the RF Hub shows that when the car is in drive it agrees with this.
In neutral it just shows ????
Reverse shows neutral and Park shows as reverse.
If the diagnostic tool is not giving us false information then this might be the problem.
The RF Hub will not allow the starter motor to engage as it thinks the car is in reverse.
If anyone has a 15 to 17 Hellcat and a snap on diagnostic tool that they could plug in and see what their RF Hub readings are that would be very useful as a comparison.
We ran out of time to do some more testing at the relay end
Shifter handle "jiggle" test make any difference???
Lord Hellcat
Lord Hellcat
Barking
United Kingdom
no difference Bull. All the other ecu's like ABS, transmission all see the correct shift position. It is just the RF Hub that goes one shift out
