"Project Demons Breath"
Thread Starter #761
That is a really nice trailer .....
Thread Starter #762
Driveshaft 2.0
Driveshaft 2.0
At least there isn't a cast adapter.🙃
Did you install it, how did it do if so
Thread Starter #765
Thank God.......
Thread Starter #766
I'm going to do the install tomorrow.
You get your wiring question answered? Car's looking great! How'd you relocate the ps res?
Thread Starter #768
@Speedy!
Yes I did get the wiring question answered . I had to get a new connector from the dealer .
Thanks . I'm really happy with the out come .
I'm going to do a write up of how I relocated the power steering resiviour. I just want to test it on the road first .
Thread Starter #769
Well folks the drive shaft is in and the exhaust is back on . I'm just waiting on the new windshield washer hose and nozzles and a new connector for the fuel pressure sensor . Then I will start planning my next round of "sneaky"
Nice goin, keep it up.
Now if I can only play shuffle the cars game. I might be able to get stuff done myself. But I guess there isn't a big hurry yet. No where to go.🤷‍♂️
Thread Starter #771
I'm patiently waiting till may so I can at least drive the car and get a road trip or 10.
Thread Starter #772
@hellno
I must say the installation of the CCI driveshaft is quite easy even on jack stands .
I cut an Allen wrench off and put a deep wall socket on it with a extension on it to tighten everything up .
8mm Allen wrench , 8mm deep wall and 3/8 extension
Thread Starter #773
While I was "rain X" ing my glass on my car today I noticed a surprisingly large amount of bug guts smeared on the INSIDE of the glass!
Goodyear
HellCat Challenger
Looking good man! Standing by for reviews on the driveshaft and how much you like or hate it LOL. Car looks bitchin with the new hood!
Thread Starter #775
Thanks . I will definitely keep you posted on the driveshaft.
Thread Starter #776
Ok so I broke my connector for the fuel pressure sensor. It took the dealer awhile to locate a repair kit but here it is .
It even has preassembled wire leads in 2 different guages and shrink wrap .
Thread Starter #777
And for those of you wondering how I got around the power steering resiviour here are a couple of pics from my mock up . I used the top return fitting and resiviour from a 6.1 car . I was quite surprised the see when I removed the resiviour from the hellcat pump to find the threaded hole for the retaining bolt just like the 6.1 pump . I did have to dig in to my O-ring kit to find an o-ring that fit properly . I mounted the resiviour right beside the brake resiviour so I can check the fluid easily . I also put a heat shield over the hose as I ran it with the A/C lines .
@Speedy!
Thread Starter #778
My OCD was working in overdrive . I had to put the windshield washer squirters in . I have a functioning windshield washer system .
Frenchcat
t-r
Nice and clean setup[clap][clap][clap]
So I have a BT cap on my PS pump and it's REAL close to my coil pack cover. I've been looking if I can space it up 2-4mm. Do you happen to have a picture of the res off the car? I'm having a hard time seeing how it bolts up. Nice clean solution you did there. I'd paint the straps purple ;)
