heat exchanger or chillerkiller
thought id be better off with the heat exchanger, but i kinda like the idea of a chillerkiller even better. guessing its one or the other, any thoughts appreciated before i purchase one.
This is not my daily driver.I have 71 passes at the drag strip and 2k miles on it. I do drive it fast under boost as often as possible...
Chiller Killer is a HX but uses a 3 way valve and displacement to achieve the temps. Can't do it with a heat exchanger alone. Don't let some one blow smoke up your ass with out a chiller. My next inter fron name,,, Chiller to be Chilled.
Heat Exchanger or Phase Change?
Road Course or Drag Racing?
Respectively...
That is debate fool of how many how many passes of coolant passes. How many inter coolers are involved. Pumps, coolant recoverees, alot to configure. Like this strawberry shake. Cream or no?
Respectively...
a lot of drag racing, haven't road coursed it yet...
I run a heat exchanger. The chiller seems to be prone for problems especially if not installed correctly.
