Dumb Question from a Novice
20HCM6 22RENBS2
About how many good passes should I expect from a pair of 305/45R17 MT ET Street R's in a RE doing 1/4mi? Sorry for the novice question, thanks.
It depends on how you use them. Huge burnouts, not long.
69 is a better number
It will depend on if you use them only at the track or if you drive on the street a lot with them. Also the longer burnouts will wear them out fast. When it's hot out and good prep at the track, you don't need as long of a burnout. When it's cold and the track is cold is when you may need a longer burnout. Try to do no more of a burnout than is necessary. This will depend on your power level also. The more power you have, the more of a burnout that is needed possibly.
But I normally get 1 > 1.5 years out of mine, depending on how many times I get to the track.
Trackhawk, RS3, Golf R
Probably 40-50 or so depends on burn out.
Till they dry rot on the rack. Use em on the front, a bit longer.
20HCM6 22RENBS2
Thanks, I didn't put together that a longer burnout was necessary on cold days when the air is probably better. It would only be at the track, I live 15mi away. I'm guessing from watching others that most of the wear is warming up the tires. So about how many runs does 1-1.5y translate to?
