Added Fore dual fuel pump
Rellcat
Pana
So I added a Fore system from Livernois and everything went in smooth. Good instructions and all the parts (except extra wire and a relay) were in order. I started it up and I have my orange fuel gauge light is blinking. Fuel reads 1/2 tank like it was before I installed it. Any idea as to what is going on?
Wires backwards on fuel level sender?
Rellcat
Rellcat
Pana
No. I switched them thinking that would be the case. All is still the same. I’m thinking I am going to have to pull the fuel pump again and test the sending unit. Maybe something got knocked around while installing it causing it to malfunction.
Be sure to post up the solution when you find it. Gotta be something simple I'd think. Scan for codes as well might give you a hint.
Rellcat
Rellcat
Pana
Will do. Car is put up now. Got cold and salty here. Going to move it to my shop this week. Had to get some other stuff out of there first.
