Let’s build a race car
Am I insane?
  • Total voters
    22
Thread Starter #841
Im just gonna leave this here.
10* of timing and its barely breathing hard. Shakedown passes in March coming soon. Learned a lot about turbos, hemis, what they like to see and th400s
Thread Starter #842
Full vidya here
1200HP Turbo 426 Hemi Makes a wild dyno pull
Oh man, you certainly have the torque dialed up! Nice work. You going to be able to turn up the “upper end” HP a bit more? That looks like a partial throttle organism!! It is going to be mean.
Thread Starter #844
Right now theres nothing to turn up, its at 25psi, 10* of timing. I need to make hits and see where the car will land. All I want this year is 8.5 index.
Good luck. Have fun, and damn hold on, the shift point looks pretty obvious then.😉
Wizza
Stafford
At this rate the car will land two counties over from the launch
Thread Starter #847
Testing transbrake and two step today. March 1st cannot come fast enough.
Thing is going to be a monster, can't wait to see it in action
Thread Starter #849
Final pieces falling in.
Thread Starter #850
It has been a mad scramble, but it has all finally come full circle.
First passes 10.9 @ 127mph on 3psi #2step #dragracing
It was not a day to go full nutters or set the world on fire. It was a day to Test AND Tune. Learned the following.
1. Need bigger radiator and fan
2. Need bigger trans cooler or relocate it. Might fab a front mount. Under car has a lack of airflow
3. Car does not require a lot of power to go fast.
4. Holley is stupid easy to tune and I love the platform
5. Havent done this since 2023, I feel whole again
Congrats man! Great shake down, confirmed laundry works and all systems go 😎
Sure he appreciates the KUDOS.....now where's YOUR PICTURES.?????
Thread Starter #853
She's evolving.
No more pilot chute, trans pan temp sensor is in right spot. And air to water is in place. Will be doing licensing at Cecil this Friday.
Thread Starter #854
Also installed a 3500cfm brushless fan. Shit is a game changer. Radiator stays mega cool.
