Anyone done an electric power steering conversion?
Jroc
Jroc
Wasaga Beach
If you have the fund patience and access to all the parts I’d do it. Interested how you came across everything
Basically what we are doing is changing all the harnesses (headlamp to dash harness, chassis harness, and dash harness) to 2023 Redeye harnesses, the engine harness we are using is a 2023 D170 harness as that should be the only harness specific to the D170. Since the D170 uses a standard 0-5v reading for ethanol content we can use the innovate motorsports ethanol content sensor I already have and tie that into the D170 PCM. We are going to use a new D170 PCM, and all new modules, and program the D170 PCM using a wrecked D170 VIN. This will get Witech to pull all the EFD files for all the modules for a D170 and flash the new modules. I also have a new D170 RFHub with keys.
Is it something thats worth it for everybody, probably not. But for me having a 2015 without a lot of the features that the 2018+ cars have and the car being apart and the harnesses needing to be changed, I figure it's worth it.
Sounds like a solid plan, let me know how you make out and what you had to do. I a8 swapped mine from m6 and functions like it left the factory with it. People said I was nuts for doing that ha
