NITTO 555R GEN 2 CHEAP! 20percent off
Worcester
MA
Just ordered the 315's through them. Says shipped to my door in 2 days and came to $619.10! Time for a smokey burnout to give my R888R's the proper send off! :cool:
You guys all getting 315s, assume you did the grinding cutting deal on the inner fender?
I did , I run the 315 DR too ;)
No grinding cutting here for my 315's 😛
Doublewide
Little Rock
AR
Nittos usually run a little narrow. I didnt have to do anything to fit the 315 NTO5R
TheRedKey
Law Enforcement
Port St Lucie
The new 305 is 312mm and the the new 315 is 317mm fwiw.
And the 315 is 1/4" taller & only weighs 1/2lb. more than the 305.
Matt someone with an SRT
Newtown
Just put the tires on the Redeye. Ground was mostly dry but not best condition.. I stomped the gas from 20mph in 2nd and it only spun at the top of the rpm a bit and regain traction immediately. Was very impressed. Did like 30 percent throttle in first gear and just took off.. with the pzeros the car would just spin. Night and day difference over stock all season 305s. And I didn’t even warm the tires! Was just testing cold and they worked right off the bat. Was like 80 degrees here the other day was a bit humid and misty. These tires have my approval.. can’t wait to get some #s this weekend. I’ll report back
Nice , so you did the 305's ? …..what tire psi cold ? ..... I think 28 > 30 psi might work.
Newtown
No 315’s on the 11inch devil rims. They were at 33 psi I aired them down after the run to 30 Psi.
This is what Nitto told me for my Challenger.
Based on the information provided, the calculated inflation pressure for your tires is 29 PSI cold pressure.
For drag radials, a burn out is recommended in order to bring the tire temperature up between 160-220 degrees. At the track it is advised to start with 20 PSI and decrease in .5 increments till you get your desired result. You do not want to go any lower than 15 PSI as this may result in rim slip.
I get rim slip even at 22 psi , in most cases 22 psi at the track works for me , I agree the nitto's need a good burnout , for the street i will see how much the psi rises after driving a while & adjust to maintain no more than 32>34 psi.
OK thanks , it's sounds like their doing the job, can't wait to get mine.
Worcester
MA
Just curious where you are getting these measurements? By going off of the Nitto webpage and their advertised specs actual measurement converts to metric as 312.93 and 320.04 respectively.
2fast4u
Edwardsburg
I can say that the 05R's I put on factory WB devil rims in 315/35/20 had absolutely no issue with clearance anywhere. They are taller than stock.
762CAT
762CAT
Somewhere in...
SC
Hellcat Challenger & Charger
Thread Starter #36
Arrived today on schedule. Look real nice and the compound feels pretty soft to the touch like a new ET Street R which is completely un-scientific but it's all I got for the moment. Lol. My 555Rs still have a lot of life but I'm probably gonna swap em this week anyway. Keep the others in case I catch a nail. That's what happened to the last set, unfortunately.
View attachment 17968 View attachment 17969
They look sweeeeet !
Beast707
Carol Stream
2018 Challenger WB M6 Hellcat
Can't wait to hear your impressions between the 2. Unfortunately I went from Summer Pirelli to these need I say more.
TheRedKey
Law Enforcement
Port St Lucie
Some random conversion site Google plugged in. 312 v 312.9 tomato tomatoe, however the 317 IIRC is the NT05R I was using as reference before the 315 R2 specs came out.
So are those 305/35s on the 9.5 inch wheels there or do you have 275/40s?
