Garage Upgrade!
yellow_hellcat
Lincoln
NE
The boys from ChampionAutoLifts.com came by to install my new 4 post lift today. The workmanship on the lift appears solid and the installers were top quality also.
The garage has an 11 foot high ceiling so I should be able to stand comfortably under the Hellcat while working on the upgrades for this spring. The installed cost was just above $3k and I could have saved a bit more if I did the install myself but they require a forklift to offload from the shipper so I paid a bit extra.
Looks good and perfect fit!
Decay
Astoria
OR
2019 widebody Redeye
Very nice!
If you installed a different door could you actually park another car underneath ?
yellow_hellcat
yellow_hellcat
Lincoln
NE
Very nice!
Agreed. I do have a two other doors, one that goes to the other 2 stall garage that shares a wall and one that goes into the house.
The lift has rollers (first picture on the wall) and it can be moved around to give additional clearance. It can even be rolled out through the garage door as it is a tad smaller than the opening!
DaveB
Penhold
I installed garage doors many moons ago....you can get your current door modified to roll up along the wall higher, then curve back. Will require proper door weight calculations, new vertical tracks, new springs, re-mounting, etc. I wouldn't think it would cost too much. Nice lift! Wish I had more height in my shop.
Sweet! I so need a lift.
yellow_hellcat
yellow_hellcat
Lincoln
NE
Thanks! I need to do some testing but the lift can't go high enough to hit the current door track and the vehicles fit within them so I hope I can avoid that extra expense!
This works
I had to have my contractor come back & change the rails
They go right up to the ceiling
You will need this if you lift your car & open the garage door !!!
yellow_hellcat
yellow_hellcat
Lincoln
NE
This works
That is true! I will not be able to open the garage doors with a car on the lift unless I have them come in and raise the tracks.
