triple pump fuel system
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
Thread Starter #21
What I hate and might can get around it I already have the rails,and 3 fpcm....I dont need nothing but the triple pumps and wiring
rookerrobert
Ridgeland
SC
Thread Starter #22
Linda,
I can understand what you mean wither I use hhp or tapped it's all the same but I want the system without return line. And talking about hhp I ordered wheels from them in march and still haven't gotten them. I know it's not there fault but it's not mine either heck I'm gonna have to reorder the tire they'll be weather rot!!!! lol
rookerrobert
Ridgeland
SC
Thread Starter #23
I guess my biggest problem is I work 6 days a weeks from 6:30 am till 5:30pm and hardly never home when there open,
New rail move more fuel?
Take a sick day and send it
Interesting setup for your sensor. The crossover just goes the the back of each rail? What is the crossover made out of? This custom made or did you buy it?
When I port stock and redeye fuel rails, they have the same, if not bigger inlet dimensions, and feeds to the injector port sizes. I think stock fuel rails can flow just as much if not more than the Fore rails. They’re all I use and I’ve never had a fuel delivery issue to the Injector because of rails. If you’re not stepping up to a full return flow through the rails system stock ported fuel rails can be enough without a doubt.
rookerrobert
Ridgeland
SC
Thread Starter #28
it was custom made to delete the fuel pressure valve since I was going to put it on the rails itself
rookerrobert
Ridgeland
SC
Thread Starter #29
those are 1/2 fore rails on there just no return and it's not the rails they way it's wired one pump is working the other isn't. Now when I hook the connection in the fuse panel both pumps work. And when you shut it off it still getting fire from somewhere and will kill the battery. I didnt put the pumps in I had it done so now I dont have and instructions on how it's should be wired
Take it back to whoever did it. If you cant, find a competent mechanic.
rookerrobert
rookerrobert
Ridgeland
SC
Thread Starter #32
the shop that done the job for me is a very well known Mopar shop. I carried it there twice for them to check it out and they acted like it was something I done after the job. And the only thing I done was drain the 93 out of the tank and put c-85 in for the guy thats tuning my car had the correct fuel. I know some of you guy may live where the competent mopar mechanics are around but where I live you have one I used other than that it's a four drive. And like most of you guys are we are about trusting who work on your car.
rookerrobert
rookerrobert
Ridgeland
SC
Thread Starter #33
