My TRX went on Fire
45-70govt
Ghetto
How many members here actually know what is meant by "safety wiring"?
I know veterans will (at least those in maintenance).
Just a thought...
Well if Hickster was still around safety wiring would mean something about baling wire.
A few years back I was flying with a student and when she let the nose down on landing we had a heck of a shudder and the plane decelerated very quickly. Unknown to us the nose tire had slowly gone flat after we took off. The mechanic found a small piece of safety wire that had punctured the tire and tube. No idea if the tire picked it up in the hangar or not, but lesson learned about making sure every trimmed piece of safety wire gets properly disposed of once it is cut. Don't be that lazy guy that trims the wire and lets it fall to the floor to sweep it up later.
the earlier chargers/challengers hellcats have caught fire. The connect they used to the fuel rail if wasn't seated right would eventually blow off. They did change the design by 2018 or 2019. Z had a trans line fighting blow off and cause a fire. But his transmission was in and out a bunch of times so still hard to compare. I guess the question would be are you 100 percent stock? Have you had any major service done to the vehicle?
We would have flight deck police calls.
The entire company would stand shoulder to shoulder and walk the entire flight line looking for FOD.
I’m still trying to figure out if the braided line is part of the hard rail or separate that can be back ported to earlier cars. Do you know @jonx96? Since you’ve had the engine out a few times
I safety wire my main fuel line to the rail and the cross over to the rail as well. I’ve heard of a few blowing off so I took an extra step to make sure mine can’t.
Anyone remember FamilyCruizin'? The speculation was he torched his
In my recent valve cover swap on the '16, I had to disconnect the main inlet line at the rail for the first time it had ever been off since car was made...I'd be lying if I said I didn't recall the Family Cruising fiasco and thinking about that thing coming off. Can't tell you how many times I kept pushing and pulling it to make sure it was good after reinstalling it. It has a latch lock so the fitting button cannot be pushed when it is in place - really can't see how it could blow off in normal circumstances, unless something is damaged or the joint/fitting design has inadequate margin against the blow-off load on it?
Mike - any pic's of how you wired yours?
FOD!
never heard of a MOPAR inspector, but the odds of any inspector in the corporate foodchain admitting to identification of a potential material defect, or manufactoring defect/error are about 1 in a billion
a real fire/arson investigator or insurance investigator might be more reliable. I'd expect the FD that extinguished it to have filed a report, that'd include an opinion on the ignition source/cause
y'all filed a complaint with DOT/USHTSA yet? shouldn't take more than a couple incidents to get an investigation started, especially where fatalities or injuries are involved
Just curious..what's a y'all...:unsure::confused:
06SRT10NR
Knobnation
a common colloquial term, informal form of address for a non-specific number of folks:geek::geek::whistle::whistle::coffee::coffee::coffee:. in this case Have you filed ...:unsure::whistle: , or maybe You all gone done reported that sumbitch:whistle::whistle::giggle::giggle:
Lol.
Let's see:
It can be singular, as in "y'all".
Or plural, as in "all y'all".
Probably means the same / similar to a New Yorkers "youz guys".
This is proper, and how I was taught by a co-worker from the South, and I've went with it ever since! :)
Lol.
Let's see:
Shoulda known it was some sort of Southern back yard jibberish variation of pig Latin....Grant shoulda made all you stump jumpers go back to school (5th grade) before we let ya back in...and "youz guys"..is P.A. talk..not NY.
06SRT10NR
Knobnation
btw, anyone heard from hickster lately?
Last I heard..(second hand)...his HC's gone..(his brother sold it)...lost his lic...and may be in some kind of assisted living
I can’t picture what part you are talking about
Ever write a post and attach a picture of the text to the post? Me neither.
The line that connects to the fuel rail, its braided in 2018+. Can that disconnect from the fuel rail at the firewall? On 2015-17, it’s a plastic piece, and can be disconnected at the main black metal fuel line. Here’s a pic of my old one. White clip connected to the fuel rail, green clip connects the the hard metal fuel line by the firewall that goes back to the tank
I’m trying to determine if that piece (which is now flexible) is built into the fuel line runs under the car and up the firewall now, or if it still connects to the hard fuel line (and I can replace my plastic one with it)
Saw this on my way home from work earluer today. I see witness marks of car fires on the highway often, it more common then some think. Everyone just drove past it like it was a normal thing. I can only hope it was empty, there was no stopping in the 90 mph traffic I was in. I’m sure there will just be another black spot there on my way in tomorrow.
