Transbrake Available Now For Your Hellcat ZF 8HP Transmission.
Trackhawk, RS3, Golf R
Wasn't aware this was even a thing I will be using this with a Holly Dominator on my Hawk and using the paddle shifter as my release button.
Freaking dope! I think u can send ur TCU to them and they can modify it for u either way it's a pretty simple mod.
Pretty sure the Holly is required for this to work maybe someone else can chime in and confirm........ But since the Gateway is now available
its at least doable.
The stand alone Holly does have CAN compatibility with this unit and there are factory CAN cars that work as well but u need
the Holly for the Hellcat as far as CAN goes I believe. But they do say it works without the Holly just not sure how.
https://www.turbolamik.us/tcu-accessories/tcu-turbolamik-full-kit/
https://www.seemslegitgarage.com/tu...fDLwkrfjt5zZq1C1OFsVDpkOqhxcVpKLISY5_l07wZ_ol
https://www.facebook.com/groups/352121570078238
I heard it's for just setting up an 8 speed Trans in a "Swap" Car so that it's not an automatic anymore and it's a manual Transmission. :unsure::unsure::unsure:
No. It has 8 different driving modes and can select from Auto, manual, transbrake, sequential, etc.... BMW guys use it all the time in their auto 8HP.
Why can't they make the trans with a transbrake like the demon? So it would work with the factory pcm...
Interesting.:cool:
8 driving modes - From an OEM automatic feel to full race with a flip of a switch!!!
Manual, auto, semi auto shifting mode using a shifter, sequential style shifter or paddles
Transbrake option
Automatic Adaptation
Self diagnosis with error codes showing on external display
This TCU also supports a digital clutch so you can drive it exactly like if you were driving a manual trans car.
Clutch is digital but world and feels like a regular clutch
Your ZF 8HP gearbox will need a modification to bypass the internal TCU. PCB board is soldered in place of the factory TCU and all gearbox commands will be executed externally using TurboLamik TCU.
I tried to find a Video of a Hemi Vehicle, do you have one?
TURBOLAMIK - 8HP swapped Lexus Sc300 - 1000 hp
Interesting.:cool:
Transbrake option
It's pretty new as of 2025 so I don't know of any hellcats with it yet. Seems to work well with the Holly. A real freaking TB would be dope tho.
Yeah it would. Probably just need a few lines of code and an unassigned button and it would work
Somebody, then with a knowledgable Hemi Holly Tuner, 6.2 Hemi, and and an A8, will be needed for the R&D. Maybe you can get your Trackhawk to be a Test vehicle for them? 😎
@vortecd 's signature quote
"you can be part of the problem, or part of the solution"
"without DATA, you're just another person with an OPINION"
" without a real world test, it is all just a guess"
~Linda
Linda just for the record Sipple is releasing a Transbrake for the ZF trans in one month! Its $3k. Guess there won't be much need for this......
~Linda
23 Challenger Demon 170
Sipple has been testing this for quite sometime I believe.
I spoke with Jon, and he said that it's been in the making for 2 years. He will resume testing in about 30 days. Maybe by the end of the summer, he will release it if things work out well.
Price wise 3,000 could be a starting point. I guess that will depend on the cost of things when MFGing happens.
rookerrobert
Ridgeland
SC
2016 hellcat A8 and 2016 M6
~Linda
your correct there are some smart guys on here and tuners also.......I bet some of you guys could do it!
rookerrobert
Ridgeland
SC
3k??? Does it come with a trans rebuild?
lol......yeah I was thinking the same thing.
3k and that's all you get? Kinda pricey. Any takers?
I think for u hellcat guys/gals it might work. Not so sure on my heavy ass Trackhawk tho...... Be dope tho but im betting it grenades the trans. Probably work great for u lightweight Hellcat guys tho.
So did this ever go anywhere?
Are the thumbs up a yes or what?
Not sure I would call them light lol
Ha yea I guess ur right bro but compared to the tank I roll around in its light AF lol.
But ill be down to like 4500 lbs soon so hopefully I can hang with them Hellcats.....
...there's 4500lb trackhawks and I'm still over here scaling out at 4875lbs with driver in my charger?
BRB. Gonna go for a new haircut. I heard the Cobain Combover is making a comeback.
