Which replica is an EXACT match for the 5 spoke?
In design, curves, angles and finish to the OEM 5 spokes and factory center caps.
Curbed one on drag week and if it's gonna be a 175 dollar repair...another less than hundo gets me a new wheel.
May order 20x11 for the rear and move those 2 up front. If said company has that option (20x11)
What say peeps?
I have the HR5s, they are close but not "EXACT".
FYI, the guy that designed them said he HAD to make them different to avoid copyright.
Decay
Astoria
OR
2019 widebody Redeye
Best looking wheels IMO!
Dinged one of mine when,off the car, it fell over in the driveway while detailing.
Big fan of my 11x20 HR5 Replicas as well. I don’t have an oem to compare it to but I do remember the difference being subtle. Also, the oem center caps fit, which is not the case with some others.
Depending on offset 11s may be too wide. I had a set of bravado 20×11 with offset of 21 i believe and I thought they stuck out too far. Had tires mounted but never ran them and sold them. I had 18x10 , 20x9.5 bravado tributes for my daytona to run different tires.
@vortecd Here are mine well inside of the Phillips flares as well as almost completely inside the 1/4 with just a bit of poke. I don’t recall the bs of the wheels however. I had to ever so slightly message the plastic well liner. No hammering the ribs or anything like that. IMG_4725.jpeg
Under-Pressure
Space Coast
Stellantis 2dr
I ran the Voxx Replica 10.5” wide on the rear of my Redeye. They were almost a perfect match to the stock wheels.
@vortecd Here are mine well inside of the Phillips flares as well as almost completely inside the 1/4 with just a bit of poke. I don’t recall the bs of the wheels however. I had to ever so slightly message the plastic well liner. No hammering the ribs or anything like that. View attachment 145831
I would say yours sit in nicely. I would just make sure on the back spacing so they do. Aftermarket wheels are not all the same. My 10.5" are +25 offset. The factory 9.5" are +18
Decay
Astoria
OR
When I run My square set of 20 x 11's they eat up my rear flairs...
Those are the Devils rim jobs.
My 5 spokes are 9.5 in the front and they are less destructive.
Trackhawk, RS3, Golf R
U need 1 inch spacers bro.....
@GNBRETT I’m not a spacer guy. However I wouldn't object to a rim a little less backspace. I don’t believe the wide body rims would work either though.
Ronin
Muspelheim
'22 Challenger Hellcat
^This, I think…🤔
Whatever it says in my signature, I can’t see it on mobile. 😬
F
Unless someone has an oem five spoke they would like to part with that's probably the route I'll go. I didn't want to lose the ability to rotate all four tires but I may just bite the bullet and do the 11s for the back after all. I'm leaning toward keeping it after the drag week performance and selling the Cobra that I picked up in April.
So if anyone may want a '97 SVT Cobra with under 35,000 original miles with a folder of receipts and manuals an inch thick I might be your guy.
