HELLCAT 1/4 MILE TIME LIST
Phast Hemi
SHELBY TOWNSHIP
2016 hellcat Challenger A8. The world's first 9 second stock boost hellcat. Wheels/tires, IE dual pumps and tune, injectors, 1 PC shaft,3.09. car never made a pass with fewer than 5 factory leather seats in it. 4600 lb race weight. A truly marvelous machine.
Must not be that many hellcats I’d figure by now there would have been more post I think meancats timeslip intimidates them 😂😂
Probably SO :LOL:, well I might be the slowest 1 on this thread , but I'm still proud of my PB et. [bootyshake] :LOL:
Thread Starter #23
I CANT BELIEV THAT WE ONOY HAVE THIS MANY ON THE LIST
ellenton
2016 mango hellcat challenger
OKay - here's mine from a private rental with Marc Heidings this past weekend - my plan was to run back to back runs all day and then do track whores next day too - only ran 1 run - launched easy and did it with my soft tune - and the guys pointed out my MTs might be toast, no smoke on the burnout - second run went hard off the line and broke my DSS - lol - dems the breaks!! I was expecting to go 9.3's ....... oh well!
My 60' is normally low 1.3's as you can see last time out
So I was definitely making more power - added 3 mph - Until next time!
Mods -
Barth 900 kit
demon springs
Sphon adjustable arms
my own toe links
my own ram air
interchiller
7 gal trunk tank
phenolic spacers
15" conversion front and rear
Racestar wheels - front 15x3.5 - rear 15x10 w/ beadlocks
hoosier 28" front runners
315/60r15 MT radial pro
full interior
Thread Starter #25
Fu
View attachment 8872 View attachment 8871
Mods -
Barth 900 kit
demon springs
my own toe links
my own ram air
interchiller
7 gal trunk tank
phenolic spacers
full interior
Fuckkkkk your fast , awesome times brother 👍👍
Thread Starter #26
Thread Starter #27
I remember now we helped you push it on the trailer, sorry about the bad break man
FFBOS
Mount Prospect
2016 Hellcat Charger
Mods -
Barth 900 kit
demon springs
my own toe links
my own ram air
interchiller
7 gal trunk tank
phenolic spacers
full interior
Is your cradle locked out?
What made you faster MPH wise, you get a tune revision or was DA great.
ellenton
LOL - my emotional support crew!!! You ran great - hope you had a good time at the track - Marc is an awesome guy
ellenton
Cradle not locked but will be now -
I was actually running my base tune with 17 degrees of timing - the reason for the increase in MPH is from the interchiller I installed - my IC temps are 55 degrees at the line and my IATs are usually ambient or just above - at the end of the quarter my IATs are just touching 100 degrees and my IC temps are usually right around 80 degrees - they used to be MUCH higher
Thread Starter #31
I need to do something to cool mine down my 9.48 run my iats wer 125 and eneded up 144,the 9.47 run in Kentucky dragway started at 99 and eneded 123 ,I think I need that nitrous spray bar for my front mount
ellenton
best $$$ I’ve spent so far - no ice needed - no additional fluids - just using ac 624C5F2A-2BB6-4DB5-80EB-C97BF9EF2256.jpeg 529BF7AC-6B1C-4969-ACFF-150D6FAC196A.jpeg
FFBOS
Mount Prospect
Yea, the chiller systems are awesome for drag racing. I used to be 160+ at the end of the 1/4 with these little pullies. Now I'm 120. Recovery starts happening as soon as you let off the gas and head for your slip.
I just locked out the cradle yesterday. You can see on your launch pics how close the tires are to the front of the wheel well. It HAS to be moving a lot on this 60' numbers. The lockout should prevent that or make it a lot less. The driveshaft at that point is getting pushed together.
You break an older style DSS? Any idea where it failed?
Markp
Fuck Trudeau
Where is the list? You lazy bastards.
That would be hellno . He started the thread
ellenton
broke my ballsack - lol EB0C7BF1-9EB9-4A9B-8690-C6F6EB9B158C.jpeg 8D2A084B-2B8F-4443-92EF-C96E701822F0.jpeg C1997F2F-A752-45D2-B399-A68DB001DEC6.jpeg
I'm too stupid to make a list/chart. If I could then I might be able to update it.🤷‍♂️🤪.
Markp
Fuck Trudeau
Just copy the redeye list.
Ok then an update. I'm too stupid to copy the RE list.🤪🤣
