Bolt On Parachute Mount
Trader history for jonx96 (0)
It is finally here!! High Quality! New Bumper! No Attaching to the Stock Aluminum Bumper this is stronger!
https://mooredperformance.com/produ...-15-24-spring-launcher?variant=47751222067503
15-24 Dodge Challenger parachute mount.
SPRING LAUNCHER Option
This is a bolt on mount
Uses 1.5" dia 4130 tubing
Mounting brackets are .172 thick laser cut steel
TIG Welded
Powder Coating is also available. Lead time for coating is 7-10 days
Requires drilling hole in the bumper for tube to pass thru. License plate will need to be notched for tube. Hole in cover can be covered with a plate frame.
Can be quickly removed from the car with 1 bolt.
*Parachute Not Included
*Release Handle Option coming Soon
We believe we have one working for chargers. If you have a Charger I will get you in touch with MAF Racing.
Very nice. Just a thought…. Make a templet that overlays the license plate showing where the notch is. After the plate is notched, it will show where to drill the hole in the bumper. Trying to guess where that hole goes is a bitch. You can imagine getting that wrong 😳
Strap ons fer da gals 2 day at Ray Jays Cheer Layderz. Yee Haaz.
The hole will very a smidge from setup to setup. There is a small amount of adjustment with the bumper install and when you tighten it down.
But yes. I still need to cut my plate I should at least include a picture
Jon-MooredPerformanceLLC
Martin
2018 Dodge Challenger Hellcat
Shipping out today but here is what it looks like without powder coating
Latest Forum Posts
