IC Chiller install & review
catdad
Lake City
My chiller keeps the stock blower coolant at a max of 90-100 at the end of the 1/4 without an extra tank. I have the 3-way valve but have mine set up to turn off the chiller when the front heat exchanger is on. Ill see if I can find my data logs to show a start and end temp. I also just installed the blower spacer plates and it has made a hell of a difference on temp and heat soak.
U
If you want an aux tank, I have a charger trunk ice box for sale! Obo and will deliver! Just doesn’t fit right in the challenger trunk
U
I’m pulling the trigger on a chiller. What’s everyone’s thoughts on this instead of the 3 way bypass valve for the heat exchangers? I want something that’s going to automatically let fluid through the heat exchangers at the top of the track in case things get too hot (no aux tank)
https://pnptechworks.com/online-store/ols/products/xn-high-flow-bypass-valve-95f-12orb-ports-bcc
Also ended up just going with the 3 way valve
Hatermkr
West bend
2016 helldemon
Must have went with a ic chiller
I have a chiller at home and 3 in da stock lot. Just add an 3 way valve. Like sade up stairs. Eazy, cheap, fast. Unda least youz unt 2 go wit a primary- sexundairy system. 3 way valve, yepper.
U
Getting ready. Found a bolt from my crash beam I thought I lost 4 years ago in the heat exchanger air duct lol. You can see the worm clamps where I’ve had this all apart before
U
I did. Hopefully it lives up to it’s name. I’m hopeful. Figure would have better customer support and if there were any issues from Sumit and Charlie since they’re nearby/in the states
How about you install it per Charlie and Sumit's instructions and use it like 100% everyone else has done. Stop frankensteining everything. I make way more boost than you and it has cooled down every time to below 100 on return road once the system kicks in.
Hatermkr
West bend
2016 helldemon
I did. Hopefully it lives up to it’s name. I’m hopeful. Figure would have better customer support and if there were any issues from Summit and Charlie since they’re nearby/in the states
I ended up a killer chiller off and put on a innerchiller.
U
To be fair, my car is literally Frankenstein’s monster
U
I was going to go with FI, didn’t want to wait weeks, deal with customs, and deal breaker was having it mounted in the front. If I have to get in there again (which I have/will have to) I don’t want to deal with moving it
Day stole my idear.
U
Kit came in. Very impressed
It is very impressive. Ass speacily aftah snot spending any munies on R & D.
U
U
Getting mocked up. If you already drilled out the spot welds on your crash beam (like I did) I recommend pulling it completely, makes life a lot easier
Now dat is waz I am turkin azbout, wile I am wacchin da fooz canell, clean and da eazy 2 gester 2. PJ da oyestar man oystah on a stick. Wen youz blow upster da turbinez, eazy 2 replace em whore reduilt tem. Dare youz goster. Ander luuck at dat cuulin system. Had 2 beez frum Florider.
U
Just got back from Lowe’s with a nice hose cutter and insulation. Hose still isn’t here yet 😑
Latest Forum Posts
