MSHS Orlando March 24th - 25th
Ya I was going to give the car one decent first hit. But after hearing about yesterday idk if it’s even worth putting a hard hitting tune in for one pass.I guess I’ll decide when I get there. I’m not thrilled with the noon start. With it was earlier
people in florida must sleep late:unsure:
D
Thread Starter #182
It will probably end around 11 - 12 tonight.
why it needs to start earlier
@jonx96 I guess it won't be rush for you setting up this morning
D
Thread Starter #185
Track will be hot at 12ish. He should be setup and ready for some test hits.
Track will be hot at 10ish. He should be setup and ready for some test hits.
Gates open at 10
D
Thread Starter #187
@jonx96 Well is is raining at home with snow and ice in some areas with a high in the mid 30s expected. Wanted this rain during the week. As long as they don't put salt down roads should be clear. Sounds like it turned into sleet. Don't you miss Michigan:LOL:
Hatermkr
West bend
2016 helldemon
8-12 on the other side of the lake
I’m also done with OSW when you can only hook one time in 3 runs leaving easy that’s enough for me! If the event’s aren’t in Bradenton forget it!
Hatermkr
West bend
2016 helldemon
I’m the same way at my home track makes it not fun. I’m going to put adjustable shocks in mine to solve this problem. Be worth the 4g
D
Thread Starter #192
I've been trying to hold onto hope that things would change but it's pretty much diminished at this point. The last 4-5 times I've been there, only once were things any good. 😢😢😢
Is this a track staff issue? Many events occur at OSW all the time.
I've seen these events run till 3am so buckle up.
click on it, it works
Jon has made a couple of passes. Should be close for the 9.50 class leaving soft
I’m watching. Makes me want to go uncork the Hellcat!
Jon won round 1 9.52 133 he was way ahead
Jon broke out round 2 9.47
Hatermkr
West bend
2016 helldemon
