Mecum Kissimmee 2023
So it started yesterday. Next week will be the good stuff
You can usually find a few good deals this week.
Amazingly fugly...
Just because you can, doesn't mean you should...
OMFG!
I thought this was a custom job...
But no, it seems to be a factory build!!! :oops::eek:o_O
Coronet back door?
Seriously, the lines on that design are SO BAD, I was checking to see if it was a photoshop job...
Might be a coronet sectioned into a Cuda front and back clips?
Unknown, but whatever, however, whoever, it's just BAD...
(I didn't even know there was a 4dr 'Cuda)
There isn't.
So the window sticker is made up as well then???
It said somewhere that it was built in 2016 by some car builder.
I may not sleep well tonight with images of a Trans'Cuda running around in my head...
Where's @Jimmy N. when you need him...
:p
After looking at it again. I'm thinking that it is a coronet with Cuda front and rear clips instead of the other way around.
Complete fail in the body lines as shown...
Other areas don't work either, but these are kindergarten bad....
Where's @Jimmy N. when you need him...:p
Sorry, after throwing up repeatedly I had to deal with the dry heaves.
