On the spark table, wot, I want to add more values for both the X and Y axis's?
AlleyCat
Oro Valley
16 HC Challenger
How and if is this possible for air charge and rpm?
Yes. You can scale the aircharge and rpm. Some shops do it some don’t. I like to scale it.
No issues with larger database and scan rate / latency?
AlleyCat
AlleyCat
Oro Valley
16 HC Challenger
I found out you cannot add extra rows and columns. You can change the scaling with existing numbers. There is a special package you can buy from HP Tuners that allows such. But even experienced tuners will not use such tables as they are very complex.
Sorry i miss read the question. I thought you meant changing the current not adding rows.
Yeah I rescale all mine to match what the car would see. OCD.
