- Member ID
- #1019
- Messages
- 412
- Reactions
- 1,400
- Likes
- 117
- City
- Houston
- State
- TX
- Country
- United States
- Vehicle
- 2016 Dodge Charger Hellcat
I think another would be the gear ratio options that can be custom set for the individual car. The 1st and 2nd ratios can be matched for the power and weight. Remember when we were comparing ratios and found that when you were leaving in 2nd with the 3.09 rear, your leave ratio was almost identical to my 1st gear with the 3.40 rear. Since then.... I'm removing close to 800 lbs from the car and will be making a little more power. The new and improved 400 I have now has taller 1st and second gears in it now. I will be getting out much further in 1st with this setup than before.
