*Removed by OP*
socalfun64
TEHACHAPI
*OP Removed info. Thanks to all who responded*
You didn't change your axis
Also if you are doing this I'd pull timing until you verify everything.
white1
Prairieville
LA
2020 hellcat charger widebody
In short, no those numbers do not look "right" however that's just from observation. There is no "right" or "wrong" as I'm sure you know if you're familiar with tuning,
I, as well as many other tuners like a nice smooth timing curve. Diablo does not offer 3d smoothing like Hptuners does, so you have to manually blend the tables.
In reality, those "odd" looking numbers might or might not matter as you might never be in a given aircharge vs rpm situation to ever hit those numbers.
I would however have some serious concerns of the 21* at WOT in the lower right hand area of the graph
My .02 cents. These cars do interpolate a bit between rows and columns, but I've not ever seen a timing map like the third picture. The first picture would be what I'd consider more standard way of doing it. However, I hope this is a tune for E85 as that's quite a lot of timing advance in there.
As you've learned it's simple to convert from DS to HPT and if you've been fooling with it for a while then you know about the comparison function and that it'd be pretty easy to straighten it out.
I've never modified the Thermal Spark WOT Blend table in the 2nd picture in my tunes.
What do the knock sensor tables look like?
socalfun64
socalfun64
TEHACHAPI
I’m not familiar with what Axis is?
socalfun64
socalfun64
TEHACHAPI
Thank You for looking at it. It is an E85 tune. It’s just a small sample of the few spark pages that were different using the compare function with another tuners E85 tune. Both are from top tuners.
I don’t know of anyway to compare the Original DS tune with the version of the same tune after it was translated to HP. Everything I’ve read or watched says it’s a simple matter and I’ve not seen any warnings.
When I get a minute I’ll list more of what is different, and also the knock sensor tables.
You should be comparing the diablo tune to your stock file.
Your air charge only goes up to 1.50. You will be going past that with your mods.
I highly recommend you take the the time to read as much as you can on the hp tuners forums espicaly the sticky’s. We are here to help but if you are tuning your self I’d hate to see the car blow up from a small mistake.
If you simply download the tune from the car (DS or otherwise) with HPT, you now have THE tune you can look at in HPT. I hope that makes sense. Then you can compare it to other tunes to see what's what.
white1
Prairieville
LA
If you'd like, PM me your email address. I'll be happy to send the tune I'm running in my car for comparison purposes
I'm e85 (e70) FIC 1200cc injectors and 2.69 upper on a redeye blower
white1
Prairieville
LA
Or...... here you go
socalfun64
socalfun64
TEHACHAPI
I totally get that. That’s what I did. Then I did a compare function to a previous E85 tune from a different tuner that was originally written in HPt.
I was just trying to double check that the “conversion” from DS to HPt was normal. All the info I read or saw stated it was a simple process. Write the DS tune into the pcm. Read the pcm with HPt. Basically thats it. If theres something else you know to do, please let me know.
socalfun64
socalfun64
TEHACHAPI
Awesome, let me take a look (comparison). 👍🏻
