The race god giveth and the race god taketh
Had her diales in for 10.0 bracket racing. Felt comfortable tuning the transmission finally.
C100C298-70DE-4794-B108-6ABF63D82FFC.jpeg 7F2FB500-3D23-4F83-9E0C-5308F2655928.jpeg 16F70697-9E8F-45C6-95A0-7777A6D421B5.jpeg
Then when making a hard left turn clinking and clanking. Thank God I had a friend with me and we pulled over into the lot nearby. Then we tested the car moving forward Straight and there wasn’t an issue, then we tested while turning and that’s when the clinking clanking woukd occur. Did the speed limit all the way home and she sits in the garage. Went out with the poppers in the ram and got tacos and I have coronas waiting for me in the fridge, just sucks this had to happen right before the event, Speaking of anyone got any axles for sale?
Thread Starter #2
Damn that sucks but glad your home safe.
10 O s
Beer & Taco s
Sounds like a real good nite aside from the axle issue blows
You'll be back even stronger next time. 💪
Back in 2015 I was 1st to break an axle and there was no aftermarket ones to buy yet. We got one directly through Dodge
I would try https://www.eastcoastmoparts.com/ they are a proud sponsor of the MSHS race, :) and in Maryland
EastCoastMoparts
2294 CRAIN HWY
WALDORF, MD 20601
240-427-1305
It didn't take too long for DSS to catch up and have them made.
I eventually had these installed.https://highhorseperformance.com/ds...hp-full-chromoly-level-5-direct-bolt-in-axle/
1-888-894-1115 Josh usually keeps some in stock. But you know it's Boost season.
Sorry you broke better before than at the event!
Good Luck
Linda
View attachment 55821 View attachment 55822 View attachment 55823
Well that sucks. Sorry that happen. It could be the diff ?
Sounds like what happen to my friends diff that we replaced, going straight no noise but when turning it would rattle & clank.
Drop the diff & pop out axles & you'll know which is broke, if axles look good & insert spline is not broke then it's the diff, which ever one it is you'll be 1/2 way there to replacing either one.
For sure was fortunate to drive her home.
10 O s
Beer & Taco s
the Food was great! And yeah unfortunately.
I’m hoping before Friday!
EastCoastMoparts
2294 CRAIN HWY
WALDORF, MD 20601
240-427-1305
Good Luck
Linda
@Linda's Hell Cat @Mean Cat grabbing coffee then turning wrenches. Once the car is disassembled Ill start overnighting parts 🤣
I worry for my axles tomorrow. I am trying to get her to leave a little harder. We will see the limits of them I guess. As long as she doesn’t hop I think I’m fine.
your mph is pretty strong. Pretty consistent passes.
Looks like fun!
@Mean Cat is correct about checking the Diff, because that is exactly why my Axel broke the Diff broke.
@jonx96 Just remember Tap ( Hook) Smash to the floor. It's all in a matter of seconds.
Oh BTW while doing a burnout try not to allow the your car to swing out in the back end. I really keep my foot down on the brake to help this not to happen.
And just don't release the brake and and suddenly move out or you could possibly hurt the supercharger pulley. But move out as straight as you can
I don't think I needed upgraded axles, I just felt safer for me.
Linda
Linda
Same here about axles, after a track rental day & I was cutting 1.41 - 60's, I knew it was time to replace axles (already had the 3.09) b4 they broke & hurt other things too.
@Linda's Hell Cat @Mean Cat grabbing coffee then turning wrenches. Once the car is disassembled Ill start overnighting parts 🤣[/QUOTE]
It's only time & money :LOL:
Linda
The back end kicking out is why I went to the burn box line lock.
It seems to help with that
YUP That would fix that problem a Line Lock. There was a reason when I asked Josh about getting one that he didn't think I should. Sorry I don't remember the answer :(
If the and or they come out in pieces ,,,,,,, then you will know.
So was underneath the rear end. Axles are rock solid. No play. Pulled the neutral safety switch and the tires rotate in the same direction freely and without effort. I’m going to take the car around the block and if it makes the clink again Ill catch it, mounting a go pro underneath the car. After that taking off diff brace and draining fluid.
Also wanted to mention was on facetime with a very reputable mechanic and we tried to manhandle as many suspension parts as possible to see if anything was loose.
Have a vid of the sound?
Localized only to the rear?
When I had the wheel mounting surface clanking early on it sounded like physical part failure to me, but was only up front. STAR fix for it was straight.forward, but when it first started it was quite dramatic and only happened on turns.
Good luck. Watching your progress buddy
