FFBOS
Mount Prospect
2016 Hellcat Charger
Pulled 100lbs out to get to "challenger" weight.
Car still has traction issues with these 305/45/17's with the power this car makes. I think I'm just going to bite the bullet and go 315/50/17.
I'm working with my tuner to get another revision for the shift points and bump the timing a bit. Car was shifting a couple hundred RPMs low from 2-3, 3-4, 4-5.....there is MPH and ET to be gained there.
Either way, I'm chipping away.
Hell yeah you are chipping away! Congrats that is moving. 315's (y)
I'm thinking on moving up to the 315/50/17's too
Is there a boner smiley?
FFBOS
FFBOS
Mount Prospect
In my opinion I think it gives you a lot of room for error if prep isn't on point. Prep was very very good last night, and I couldn't hook at all unless I squeezed the pedal off idle.
I replaced the 305 with the 315 after less than consistent 60’s with the 3.09 gears. The 315 is much more consistent. I would never go back.
FFBOS
FFBOS
Mount Prospect
Yup. I think this tire is "king", no need to go to a 15"
how much boost do you make with the 2.4 upper pulley?
Haha. Yep. Until you actually need to. My new ones... 57B7E463-E91F-4F39-AAB0-26634F09830E.jpeg
FFBOS
FFBOS
Mount Prospect
Yea, you are at "another level" now lol
HellcatMatt
Central
Wow! Great job man and still room to go!!
You A8 guys are so lucky to have the available 315/50’s too. I wish they made the bias ply in that height and width. Unfortunately the bias 28x11.50’s measure short and only have a 9.5” tread width as well. (n)
Keep gettin it done FFBOS!
Outstanding!
Dang fast.
FFBOS
FFBOS
Mount Prospect
Just received a PCM/TCM revision this morning. Hope to make it out once more.
WhipCat
In the Jungle
Nice run bud. That mph is looking real good.
Is this a street tune or a race file?
Way to go FFBOS , that is quick ! keep chipping away.
FFBOS
FFBOS
Mount Prospect
That tune was 20 degrees of timing, and shifts around 6200-6300.
I have my tune revision in the car now which bumps the timing up to 22 and shifts to around 6400. I only run these tunes when the ethanol tests over 80% on the test tube. My season is creeping up on me here. I'm hoping to get one more visit this year.
I still have to get my 315's on the rims, which has proven to be a pain in my ass getting the bead around the rim. I also have a driveline vibration that I'm going to take a look at tomorrow on a lift to see if anything is loose. If all looks well I should make it out again.
WhipCat
In the Jungle
Good deal.
Those new 315/50/17 are nice. You’ll hook real good with them.
Bud, I’ve been chasing a driveline vibration for over a year! I still have it. Let me know your findings.
FFBOS
FFBOS
Mount Prospect
Good deal.
What are your symptoms
WhipCat
In the Jungle
Vibrations is really noticeable between 60-80 mph.
While I’m cruising if I let off the throttle the car stabilized and drives perfectly still. As soon as I apply throttle, the vibration resumes. It’s mega annoying. I’ve replaced 3 driveshafts, changed 2 differentials, changed diff braces, changed wheel and tire combos, swapped a trans, replaced a right rear Shock and still nothing has fixed it. I didn’t do all that to specifically fix vibrations it was just stuff during the course of modding, but still. Super FKn annoying.
I threw a cheap BMR cradle lockout a while back. That’s the only thing left I haven’t really changed since then. I’m swapping that coming up to see. But man!! It’s annoying
WhipCat
In the Jungle
Made a video a while back to show people.
