OOF.....V-8 Superchargers soon to not be welcome here!
BMW already has that covered by playing exhaust sounds through the stereo on the non-EV models.
My '13 Golf R had that crap. Called "Sound Kommander" or something to that effect.
No way to eliminate it, either.
Prange
no longer in Chicago
2021 Charger Scat Pack
That POS will be dead in less than 5 years so….
Hey! Don’t tease me like that! 🙂
Holy cow.... nice instantaneous blast overpressure there if it is setting off air bags.
I have never e experienced that crap, and making it not driver controllable is as stupid as dodge making the exhaust computer controlled only
Ok Chicken Little lmao
stonewall
Conway
AR
2017 Dodge Hellcat Challenger
Actually, no. Hydrogen is no more dangerous than gasoline. If you're thinking of the Hindenburg disaster, it was the oxide and aluminum paint that caused it burn so quickly.
Wrong. I advise you to not smoke or strike a match over a charging wet cell battery. It will blow up like a bomb.
68coronet
Jacksonville
2020 Dodge Challenger R/T Shaker
stonewall
Conway
AR
Having witnessed several lead acid battery explosions in my life. I know for a fact that they will blow up just as in the video I posted. The Hindenburg burned! because it was not in a sealed container. The thin skin did not allow for a pressure build. The same as pouring gun powder in a small pile and lighting it with a match, vs putting it in a sealed pipe with a fuse! We are talking about too totally different situations when comparing a sealed battery with the Hindenburg.
If/when we get hydrogen powered cars, I would hope that it's contained in a vessel that's much stronger than a battery case.
As I noted above, the inflammability and safety tolerances for hydrogen infrastructure are significantly higher than existing gasoline equipment. Pilot projects in South Korea (and Norway, also above) have experienced serious problems. There's always teething pains with a new technology but with hydrogen you're not going to be able to shade tree mechanic this stuff.
https://www.reuters.com/article/us-...th-koreas-big-fuel-cell-car-bet-idUSKBN1W936A
stonewall
Conway
AR
Biden is going to rush in electric cars as fast as he can, so that we will freeze to death the first winter when the power grid cant handle the extra load placed on it, because He shut down all the fossil fuel power plants, and didn't replace them with clean fuel plants first. You have to build the techknowledgy to support the change first. They are getting the cart in front of the ass.
68coronet
Jacksonville
They attempted to implement this back in the 70's. Bogus energy crisis, electric cars, unions going on-strike (attempt to shut-down travel and limit supplies), USA to metric system conversion, 55 MPH speed limit, etc... Well, here we go again, and this time they may succeed. If they do, I suppose it was meant to be.
