Great News From D and B Auto
I'm not very computer savvy you should make me an avatar of M6M in Granite letter with Sublime letters and I'll rock it! So since he didn't respond to the question he doesn't do work on manual transmissions?
I'm prob. less computer savvy than you, lol, but the M6M is a funny thought.
Beast707
Carol Stream
2018 Challenger WB M6 Hellcat
I missed it I’m sorry but I only do automatics now , talking to @cole3986 has that effect on me 🤣😂
Cool man I appreciate it. Not many options for great M6 builders.
With a couple psi & pcm / tcm tune, it will be close to the 9's depending on DA.
From your PB, you will need almost 4/10.
I picked up 4/10 on my 2.85.
Didn't you gain 2 tenths from your tune? Add another claimed 2 tenths for the pulley and there we have it. The test car for the pulley claimed to have gained more than 2 tenths.
A car at my track ran a 10.27 to my 10.52 earlier this summer. Before the Incognito he was about a tenth slower give or take a few hundredths either way. So I'm going to try and see how close I get and the pcm will be sent out once the season is over.
Well, on stock boost, 3.09 & tuned, my PB 10.24 neg.674 DA.
Did the 2.85 & PB 9.83 neg.1424 DA , so there's my 4/10.
Between the 2 PB's is about 700 DA difference, which is about another 1/10.
I talked to a guy here in Houston, basically sea level, & he said he only got 1 psi on the incognito pulley, so it may vary, he didn't run it at the track, that was on a Dyno.
Two here with it. I talk to one guy allot and he is seeing 13psi.
We are at 197ft here.
That's good, so he ran 10.27 with it, & was 1/10 slower than you b4 it, then you should be 1/10 or so faster than him when you do yours ?
Did he have pcm / tcm tune ?
That's what I am hoping for.
He does not have a tune.
Ok, so the 10.27 car didn't have a pcm / tcm tune, so you should see 10.0's with pcm / tcm tune & may hit that 9 with some great DA up there, going to be real interesting.
In the heat down here at 3000 DA, I've ran 10.20's & .30's.
