Which Battery Impact Wrench
a526051
Austin
Tile about says it all, which battery powered impact wrench for wheel removal are you guys using
I think Project Farm has a comparison?
Never mind, he hasn't tested 1/2" drive.
The Englishman
Newbury
United Kingdom
2018 Demon
18 volt Makita,as I have the batteries ,it works well
DCF899 20v Dewalt 1/2 drive. Works great for me.
Piening2150
Toledo
2017 Charger Daytona 392
I have an 18v brushless Ridgid. Works great and has a lifetime warranty on both the tool and battery.
StingrayZ51
Lindenhurst
Milwaukee like guys said but if you’re a weekend mechanic don’t be afraid of the Harbor freight earthquake. I have the 1/2 20v and haven’t had a nut yet it wouldn’t remove. It’s a surprisingly nice tool.
greasy
HOFFMAN ESTATES
I would recommend the DCF894 if all you are doing is taking off wheels, 330 ft lbs of fastening and 600 ft lbs of breakaway torque. No reason for anything stronger like a hi-torque impact wrench from DEWALT or Milwaukee.
If you have questions on anything DEWALT or power tools in general I can help guide you as I work for DEWALT and have been in the power tool business for well over 10 years.
Sheet metal hammer.
I already had Craftsman stuff from Lowes so I picked up the impact wrench that goes with it.
Used it a handful of times and it works pretty damn good. Its only 6 months old though.
I have the Milwaukee M18 1400 ft lb unit. Love that damn thing
Same here, brushless one, it’s small, compact, and a f n animal. You can set it to 4 different modes, it’ll get anything loose or break it off but it’s moving it LOL.
Take it back.
greasy
HOFFMAN ESTATES
Just an FYI Stanley Black & Decker, the company who owns the DEWALT brand, also owns the Craftsman brand. A lot of the same technology from DEWALT goes into those tools.
2fast4u
Edwardsburg
I use the Milwaukee 18V Fuel, it has 3 adjustments for power/torque and is great...put on 1 for running lugs on, then torque to 111.put on 3 for taking them off, a breeze and extremely fast.
Thumbs up on the 18v stuff. I bought the wrench and two batteries a couple of years ago. Last year, I sadly needed to replace my old friend, a Monkey Ward circular saw that was nearly 50 years young when all the adjustment bolts finally got lost or fell out. Got a “reconditioned” or opened-returned Milwaukee circular saw for like $150 alone last summer! Looks new, acts new and wow, do I love the 18v batteries and the tools they drive. Not stringing extension cords to use a circular saw? Priceless improvement in doing stuff for this old guy!!
Try the 20v. Giant improvement over the tired old 18’s I was using.
a526051
a526051
Austin
For use in wheel removal, are the high torque impacts required, or will mid torque 1/2 inch or even 3/8 inch suffice? I'm not going to be working on bridges or anything like that. I have a Ryobi that would not remove lug nuts on my Challenger HC. They were put on by Discount tire, and I assume they were torqued to a proper 110 ftlbs. I understand that my be a bad assumption.
2fast4u
Edwardsburg
Mine is actually a mid torque model with 3 settings...rated at 600ftlbs torque for removal max and up to 450ftlbs fastening max. In mode 1, it stops right after nut is contacting wheel, maybe 10-15lbs torque.
2fast4u
Edwardsburg
Has absolutely no problem removing lugs!
MJS73
Moparland
2020 Challenger Hellcat
I have this one and like it.
