What’s the best plug n play fuel system?
Hellcat Dre
Active Duty U.S. Navy
Jacksonville
2016 dodge hellcat challenger
I’m wanting to run a flex fuel tune for 93 and e85. I want a fuel system where I don’t have to worry about the levels of running it to low and need it to be plug n play. What is the best one to get
Tapped Performance systems are true plug and play. Everything plugs into factory plugs, you cut NOTHING. Fuel hat is a FORE system, FPCM’s are genuine Dodge units, pumps are true Ti pumps not knock offs, his harness and plugs are factory quality. Rick there makes good stuff.
Hellcat Dre
Hellcat Dre
Jacksonville
I will look into them
Demid22
Nurse
JONESBOROUGH
2017 Dodge Challenger Hellcat
I second tapped performance. Took good.care of me when i need a triple pump setup. Shipped them my dual pump setup and they upgraded it to a triple with a quickness. 10/10 recommend
Yep, that’s the best one. I unfortunately did mine back before the plug and play harnesses, I have an injected engineering kit in. Same thing, only you cut and splice wires
Latest Forum Posts
