Sign Up! To view all forums and unlock additional cool features
I ordered on Saturday...delivered on Monday! This is the nicest packaged lit I think I have ever seen. Excellent, easy to follow directions! Well done!
I talked to him and was going to get one for my 19 Redeye. He said some of the newer Redeye's have brake duct cooling in the big access cover thats normally removed to change oil. It's a raised portion with inlets, right in the way of where you would need to do things.
You have to look underneath, and see if there is a raised inlet duct. I had just ordered mine and he told me this, via email. Than he credited me back! When I looked, mine did have that cooling inlet and the access panel wont work. I also got two brake duct cooling bolt on air diverters from the factory for the front of the car. There were in a box in the trunk when I received the car! They will go on when the first oil change happens!
Shouldn't be just some. I'd think all Redeye's have that duct cooling section. I know mine does, which is why I looked at it closely and noted there isn't a Redeye solution yet. The dealer put on my air diverters during PDI. I told them they were in the trunk upon arrival. They didn't know what they were, but I also had the first Redeye they ever got, lol.
Just repeating what I was told! Not knowing this was the first year! I am with you now. I am new to these things and still learning. I would agree all Redeye's have them now after what you said. Unless some Redeye's lost out on their Visine dose and got a non Redeye RX lol
Just installed my kit today while doing my first oil change. Wow, really nice. I had no issues at all. The instructions were excellent, if only everyone did it like that! I'm very much looking forward to not having to remove all those clips and fasteners just to drain the oil cooler. I also added Stahlbus valves to both the oil pan and the oil cooler drain. Plenty of room to get to the oil cooler drain plug with normal tools through the access door. Its a little tight for the Stahlbus valve but I think it will work just fine. I test fit the drain line and fitting without actually draining any oil as I had already put in fresh oil. It looks as though it will work if you run the poly hose through a hole in the under tray.
I went ahead and ordered the kit. Will be putting splitter on, then cutting out for access. I don't know what the overlap will be, but doesn't really matter, as I will cut splitter to suit. If it is a 50/50 overlap, then I will try and figure something out.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
