- Member ID
- #1070
- Messages
- 6,068
- Reactions
- 15,530
- Likes
- 402
- City
- Murfreesboro
- State
- TN
- Country
- United States
- Vehicle
- 2016 Hellcat Go Man Go
I've started playing with Flex Fuel a bit now that I have a more beefy fuel system with the dual pump drop in kit. I'll be limited on boost to where I'm at now, which is a Litens 2.72 and I see about 16.5 - 17.5 pounds of boost depending on weather. I'm running ID1000 injectors.
With the dual pump system I have quite a bit of fuel system over head with injectors at 50% DC max and fuel pumps at about 65-70% max DC. Fuel pressure is healthy at about 83psi at WOT.
I'm hoping I can start to play around with the timing a tid bit when I add E85 to the tank.
I'm curious what you guys see for alcohol content on standard 93 octane pump gas. Our local pumps claim "up to 10% ethanol". However I've found some brands of 93 octane read as high as 23% like Racetrack for example where Shell 93 will read 4% in 500HP mode and 11.5% in 707HP mode. I thought that was kinda interesting as well.
- 1
- Show All
